Body Control Module/Keyless Entry Problem
Old Apr 19, 2008 | 02:52 PM
johnt671's Avatar
Was working on a new power antenna install on my 97 GXE today. I just went out to lock the car up and found that my remote won't work. When I removed the old antenna I unplugged the gray wire from the module because it was wrapped around the antenna, and plugged it back in again. Other that that I didn't do anything else to the module. I did cut the old antenna connection off but didn't connect it up yet, but thats it. Is it possible I blew a fuse when I cut the antenna wires or did I really screw something up? Thanks.
Old Apr 19, 2008 | 03:07 PM
Nopike's Avatar
If a fuse is blown it is Fuse # 40 7.5 Amp.
Old Apr 19, 2008 | 04:04 PM
pmohr's Avatar
No more Maximas...
Chances are it's one of the three 'elec parts' fuses in the interior fuse box:
Old Apr 20, 2008 | 04:22 AM
johnt671's Avatar
I'll check it out after I have coffee.
Fuse was blown, #40 was right on the money. Thanks to both of you.
Old Apr 21, 2008 | 03:59 PM
blumax1023's Avatar
Programming
You like get it close the door turn the key to on position wait 15 seconds pull it out and hit the lock button or something like that
Old Apr 22, 2008 | 11:00 PM
Snypa's Avatar
check fuse and/or reprogram the entire system.
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Hailstatejig
Sep 2, 2015 06:52 AM
