transmission question??? need help asap!!!
Old Apr 19, 2008 | 06:09 PM
97GoldGLE's Avatar
ok so i was driving and out of nowhere i was trying to go from 2nd into 3rd i put it in and it just reved and put it in 4th, 5th and revers all work just fine but when im stopped the shifter will not move over far enough to go into 1st or 2nd....and now also my shift linkage is hitting my heat shield....what could be my problem??????
Old Apr 19, 2008 | 07:33 PM
pmohr's Avatar
No more Maximas...
Have you...checked the shift linkage? If it's hitting the heat shields underneath the car, chances are it's fallen down or otherwise needs attention...
Old Apr 19, 2008 | 08:12 PM
JtzMax's Avatar
Whatchyou say?
I would agree with Pmohr! Check the support rod and make sure it has not come loose form it's mount.
Old Apr 19, 2008 | 11:41 PM
97GoldGLE's Avatar
ok thanks for the input guys i think ill do that tonight and hope thats all thats wrong... If anyone else has anything to add plz do i appreciate it guys!
Old Apr 20, 2008 | 09:35 PM
97GoldGLE's Avatar
ok so i checked everything and it looks to be fine.. so could this be my tranny now??
Old Apr 21, 2008 | 05:36 AM
JtzMax's Avatar
Whatchyou say?
anything is possible .... it could be that the selctor rod is hitting the shift rod engagement slot wrong (i.e. if the spring is bad and not retruning the rod to the proper state of "N")
It would require you to open up the trans and see what is wrong. It's not easy to destroy one of the detent srpings (unless you noticed a very difficult shift prior, and something has broken), but as I said ... anything is possible. Dave may have more ideas of what is wrong, I have only done my trans .... he's done a few more from the sounds of it!
Sorry I couldn't be more help ... hope you get it fixed!
Old Apr 21, 2008 | 09:34 AM
dgeesaman's Avatar
Maintenance Monster
Divide the problem.
1) detach the shift rod from the tranny. Put a screwdriver into the bracket and pull/push it into each gear. If you can do this, the problem is not the tranny
2) inspect the shift linkage. you may have to drop the cat to see where it attaches to the shift lever. Also check for a torn shifter bushing.
Dave
Old Apr 21, 2008 | 05:11 PM
97GoldGLE's Avatar
ok thanks guys i really appreciate it!! im going to go try that right now and see
Old Apr 21, 2008 | 06:27 PM
97GoldGLE's Avatar
ok so did that and its not the shift linkage.. soooo its in the tranny...
Old Apr 22, 2008 | 10:59 PM
Snypa's Avatar
sounds like tranny speaking up.
Old Apr 23, 2008 | 03:03 AM
dgeesaman's Avatar
Maintenance Monster
THen the exact root cause becomes less important - you have to drop the trans and take it apart to solve the problem.
One thing you could consider, slight shot in the dark - is remove the 14mm head hex bolts and see if the springs underneath them are broken. You can still do that on the car, but you will drain tranny oil in the process.
Old Apr 23, 2008 | 01:25 PM
Pieps's Avatar
I had the same problem of the selector not moving over into first or second. Turns out my shift selector sensor inside the tranny blew up and a piece got wedged somewhere, not allowing the left rotation of the gear selector. I drained and filled the tranny a few times to flush all the pieces out, and it's been fine since.
sctludwig
Sep 1, 2022 01:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
pjgreek
Sep 9, 2015 09:30 PM
Johnny9595
Sep 3, 2015 05:18 AM
