Oil Usage on 1999
Old Nov 3, 2000 | 01:53 PM
markb's Avatar
My 1999 Se 5sp has used oil since it was new. About half 1/4 for every 3000 miles. Dealer said it was normal, called the factory, they said it was normal. Im still not convinced.
Old Nov 3, 2000 | 02:13 PM
ronskal
I'm not sure how much oil you say you're using?
Old Nov 3, 2000 | 02:21 PM
Daniel B. Martin's Avatar
If "half 1/4" means "half a quart" per 3000 miles, that is perfectly normal.
MarkP's Avatar
If you mean 1/2 quart per....
3000miles, that is considered normal. Actually 1 quart per 1000miles is considered normal by most manufactures. Howevere I've never owned a car that used that much unless it leaked somewhere.
Old Nov 4, 2000 | 01:13 PM
1MAX2NV's Avatar
try switch to 10W30 ->
Your motor out of the factory is on the loose end of the spec. Thicker oil will have fill in the gap. Nothing to worry about.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
