Adding keyless when it was not factory
Old May 15, 2008 | 05:32 PM
  #81
ZX9RBART's Avatar
Originally Posted by fanaticrockford
How to for removing the radio. After reading it real quick the only thing I do different is after removing the screw for the ashtray is to open the ashtray. I don't see how there able to remove it without doing so. http://www.installdr.com/InstallDocs...PDF/647021.pdf
It says no but is it virtually the same for Bose?
Old May 15, 2008 | 05:38 PM
  #82
Maxima_Joe's Avatar
4th Gen Parts King
Removal is the same for Bose. Just the wiring is different.
Old May 15, 2008 | 07:11 PM
  #83
ZX9RBART's Avatar
New BCM in transit...updates to come.
Old May 15, 2008 | 08:04 PM
  #84
Nopike's Avatar
I've had my Bose system out on my 98 SE it's fairly easy. One hour tops for removal and restall.
Old May 16, 2008 | 02:21 PM
  #85
ZX9RBART's Avatar
Yes I got great news. I tried a bcm from a 95 without keyless part # is 28491-40U03 in a 95 with keyless which had a bcm with part # 28491-40U00 and I couldn't get it to ender the programming mode (shut and lock doors enter key 6 times etc).
I have two bcms available that will fit your 98
One I believe is from a 97 with manual climate control part # 29491-2L900
The other I believe is from a 98 with auto climate control part # 28491-0L720
You should be able to use the one with auto climate control but it would have two extra plugs for that system on the front. The back side has the same three plugs the manual climate one has. If you wanted to do the auto climate control swap in the future this would be the one to get.
What is the part # on your bcm?
It is on the bottom so you have to unbolt it to read it.
My BCM number is 28491 0L703
Old May 19, 2008 | 05:21 PM
  #86
ZX9RBART's Avatar
WE HAVE KEYLESS
Works like a charm when all the right minds and components come together. Thanks to NOPIKE for the theory that the BCM may be option specific and FANATICROCKFORD for putting in the time to test this theory. The only thing that I cant make absolutely factory is the antenna, I plan on tying it into where the diversity antenna for the bose connects to the rear window unless someone has a better idea. The bottom line is that with a little time and some junkyard parts you can have fully functional keyless on a Maxima for less than 100 bucks.
Old May 19, 2008 | 06:24 PM
  #87
ZX9RBART's Avatar
If any of the Mods want a detailed breakdown of what I had to do for the FAQ section just let me know.
Old May 19, 2008 | 07:52 PM
  #88
Nopike's Avatar
Glad to hear you got it working. If the window antenna thing does not work out, you may just consider running a few feet of wire in the trunk as an antenna.
Old May 19, 2008 | 08:19 PM
  #89
Maxima_Joe's Avatar
4th Gen Parts King
Glad to see the BCM arrived today like it was suppose to. Did you happen to compare yours to the one I sent to see if it was missing a resistor?
Have you found a key fob yet? If so how well does the keyless work now with just the wire I sent.
Old May 20, 2008 | 04:08 AM
  #90
ZX9RBART's Avatar
I found a fob and with the wire laying in the trunk I get about 100 or so feet of range.
Old May 20, 2008 | 04:58 PM
  #91
ZX9RBART's Avatar
Well connecting to the diversity antenna didnt work so well, remote worked good but radio reception suffered. I read while searching a while back that someone had good results hooking the antenna to ground (which is kinda hard to believe as antennas are "tuned"). Is there supposed to be a 2nd antenna in the rear glass on factory keyless?
Old May 21, 2008 | 06:12 PM
  #92
ZX9RBART's Avatar
If anyone is still following this, since I already had the 2 into 1 faston connector I moved my remote antenna from the diversity antenna to the negative side (same side) of the window defroster. Works better than I could have ever expected. I was 50 yards away in the steel cab of an all steel locomotive and i could use it while the fob was in my pocket. Once again, thanks for the help.
Old May 21, 2008 | 06:40 PM
  #93
Nopike's Avatar
Cool, sounds like you are all set.
Old May 21, 2008 | 06:54 PM
  #94
ZX9RBART's Avatar
The only thing left is to (yikes) cut my drivers door panel to put in the electric trunk release. If not I may try hooking the cable from the original trunk release up along with the solenoid. Not sure which I would like better yet.
Old Jun 30, 2009 | 11:56 AM
  #95
VQrebuild96's Avatar
Hi ZX9 (or any 1 that can help) I am swapping the BCM from an SE into my GXE. The problem is that i do not find all of the cables that was connected to the BCM when it was in the SE. Are there any cables that are hidden? And the leather seat did not work with the old BCM, was it like that for you?
Old Jun 30, 2009 | 01:44 PM
  #96
pmohr's Avatar
No more Maximas...
What do you mean you 'do not find all of the cables'. Do you mean the wiring harness for it? How can you not find them, they're plugged directly in?
The BCM has nothing to do with the seats.
You aren't trying to put a 95/96 BCM in a 97-99 (or the other way around), are you?
Old Jun 30, 2009 | 01:49 PM
  #97
Ok the seats work with the GXE BCM. And no i am putting a BCM from a 95 SE into a 95 GXE and the wiring harness is not there for the front of the BCM. I want it so i can have keyless entry and an alarm.
Old Jun 30, 2009 | 01:53 PM
  #98
pmohr's Avatar
No more Maximas...
Did the SE BCM come from a car with auto climate control?
It sounds like your confusion is a BCM and a car, one had auto climate and one doesn't.
Are you saying that the seats aren't working now? They don't touch the BCM at all, so it's either a coincidental failure, or you unplugged them or something.
Old Jul 1, 2009 | 01:49 PM
  #99
"It sounds like your confusion is a BCM and a car, one had auto climate and one doesn't."
Yes that was it!!!! Thanks a lot man, everything works perfect with this BCM.
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
