need help with cruise control!
Old May 6, 2008 | 10:14 AM
maxxone's Avatar
My cruise light flashes when I turn it on and will not engage. I checked every fuse. all ok..any ideas out there?
Old May 6, 2008 | 10:28 AM
IlyaK's Avatar
The Golden One
I fixed this problem on my old 97 (I have a 99 now) by unplugging the computer for the cruise under the steering wheel and unplugging the pump thing on the firewall and then plugging them back in. I fix PC's for a living so that's always the first thing you do with hardware problems...reseat the part. Try that.
Good luck, this problem is a PITA sometimes.
Old May 6, 2008 | 10:39 AM
ExoticCreations's Avatar
I have seen this on my old 96 and my sisters 99. It does effect the cruise control function. but it is a annoying flash.I removed the battery cable and it never worked. I never tried to disconnect the cruise computer but it might work.Post back if it does.
Old May 6, 2008 | 10:55 AM
dashan's Avatar
+1
Old May 6, 2008 | 11:31 AM
Coolsaber57's Avatar
If that doesn't work, the FSM has a big trouble-shooting section for the cruise control (ASCD), my problem was my steering switch was broken. Gettin a new one now!
Old May 6, 2008 | 11:42 AM
maxxone's Avatar
thanks all! I will try unplugging the cruise and see if it helps.
Old May 6, 2008 | 12:39 PM
IlyaK's Avatar
The Golden One
I have a spare switch I can sell you for $10 + shipping if you ever wanna try that. I'm pretty sure it works because replacing it didn't fix my problem...so my switch was most likely always good to begin with.
This is a VERY common problem on 4th gen Maxima's.
Good luck!
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
