OD operates only while pulling back shifter
The OD has not worked for a while. It only works when I pull back on the shifter with pressure, and I can turn it on and off fine. But if i let go of it, it shuts off and doesn't operate. Could this be loose wires or sumthin?
I dont wanna F up my transmission or anything like dat dere. Anyone taken it apart before and could guide me?
i took out the center console and i started to take the shifer apart. Then once I got to pulling on it, i wasn't to sure expectly how the wires are connected to the shifter. I see two connections.
There is only two wires. They are soldered to the bottom of the shift ****. So just cut them back some. Strip the end of both wires and touch them together. This will either turn on or turn off overdrive I don't remember. If it work like it should doing this then the switch is broken. Either get a switch and place it somewhere else or get a new shift ****.
vingodine
45
05-21-2016 12:46 PM
Fakie J Farkerton
10-14-2015 06:25 PM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
