CEL for P1336 --- 0905 input needed plz!!
Old May 12, 2008 | 08:21 PM
mastere954's Avatar
CEL for P1336 --- 0905 input needed plz!!(UPDATED)
hey guys, im getting the CEL for this code
P1336 --- 0905 which is the crank position sensor (POS)
has anybody had to deal with this same issue and also what is the difference between the crank position sensor (REF)
and crank position sensor (POS)???
i have read the stickies already btw, i know about the taking it off and cleaning it cuz its magnetci and all the other stuff but i would like to get some input from anybody who has indeed dealt with the (POS) cuz i am getting the p1336 code and not the p1335 which is the (REF).
any input is highly appreciated
Edgar
UPDATE
So i replaced the sensor with a brand new one, also checked the connectors and they are clean and the wires are fine, erased the code and it came back a day later. i was wondering if maybe the fact that i have a fidanza flywheel had anything to do with it. i have bno clue why the code would be comming back, if anybody has an opinion, plz post it. any help is appreciated
Old May 13, 2008 | 03:02 PM
67whitegoat's Avatar
DESCRIPTION
The crankshaft position sensor is located on the oil pan facing the gear teeth (cogs) of the signal plate (flywheel). It detects the crankshaft position signal (1°signal).
The sensor consists of a permanent magnet, core and coil. When engine is running, the gap between the sensor and the gear teeth (cogs) will periodically change. Permeability near the sensor also changes.
Due to the permeability change, the magnetic flux near the core is changed. Therefore, the voltage signal generated in the coil is changed.
The ECM receives the voltage signal and detects the crankshaft position signal (1°signal).
Possible cause: bad harness or connector, dead or weak battery, chipped signal plate(flywheel), or a bad sensor.
Good luck brother.
Old May 13, 2008 | 06:21 PM
mastere954's Avatar
thanks for your detailed response. imma have a look at the sensor tomorrow.
Old May 13, 2008 | 06:36 PM
gtr_rider's Avatar
192.168.1.1
Here you are, maybe this will help..
http://forums.maxima.org/showthread.php?t=78486
Old May 13, 2008 | 07:56 PM
mastere954's Avatar
already read it Luke, thanks
Old May 22, 2008 | 12:31 PM
mastere954's Avatar
UPDATED ^^^^
Old May 22, 2008 | 12:34 PM
Kevlo911's Avatar
Kevlo for President
Check the timing ring on the flywheel to see if the sensor can read it properly
Old May 22, 2008 | 12:39 PM
mastere954's Avatar
have no clue how to check that
Old May 22, 2008 | 04:31 PM
Kevlo911's Avatar
Kevlo for President
Look where the sensor goes and look at the timing ring for chipped teeth or anything
Old May 22, 2008 | 07:35 PM
mastere954's Avatar
checked it out and found no chipped teeth. Everything looked fine. Anything else?? LOL
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
