Check front strut mounts
Old May 18, 2008 | 10:59 AM
clive's Avatar
100% chingon
My car gradually - so slowly I hardly noticed - got worse and worse on handling. I was thinking, oh it's just me, but then over about two weeks it went from "it doesn't feel quite right" to "OMG it is all over the freakin' road".
It turned out to be the bottom mounts for the front struts. The mounting holes had gone oval and the rubber was completely shagged. Well, I was a bit broke so I went with the cheap Autozone Chinese ones rather than the expensive but nice Monroes, but the difference!!! It goes around corners again without wallowing all over the place. So if your car's handling seems not to be up to snuff, I suggest it might be worth while taking a close look at the lower mounts...
Old May 18, 2008 | 01:06 PM
njmaxseltd's Avatar
Originally Posted by clive
My car gradually - so slowly I hardly noticed - got worse and worse on handling. ...............................It turned out to be the bottom mounts for the front struts. The mounting holes had gone oval and the rubber was completely shagged. .................. I suggest it might be worth while taking a close look at the lower mounts...
Bottom mounts? Shagged rubber?
You sure your looking at a Maxima?
Old May 18, 2008 | 01:25 PM
QNO_A32's Avatar
Make this a Sticky A.S.A.P !!!!!!!!!!!!!!!!!!!! ++++1
Old May 19, 2008 | 07:46 AM
clive's Avatar
100% chingon
Yes of course. The front strut mounts. I had no idea they existed before the garage took them off and showed me how ruined they were. One of the front wheels had a visible camber angle change, it reminded me of those old VW Beetles with swing arm suspension. My Max was barely driveable - it was really dangerous, couldn't keep it in a straight line. The mounts cost me around $45 from Autozone, the Monroe ones were twice as expensive. If you don't believe me, see: http://tinyurl.com/5zme67
homeyclaus
Sep 3, 2015 06:15 PM
MaxStock
Aug 14, 2015 10:01 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
