rotor brembo or oem with oem pads
Old May 19, 2008 | 08:27 PM
joew's Avatar
anyone knows if brembo "blank" or oem rotor will work well with oem brake pads.
Old May 20, 2008 | 01:56 PM
wirelessdude04's Avatar
simple common question simple common answer yes.. Blanks will work with oem nissan brake pads
Old May 23, 2008 | 05:58 AM
Rider's Avatar
Brembo rotors should work just fine.
Old May 23, 2008 | 08:24 AM
xkazik's Avatar
Brembo rotors work fine, they just rust around
Old May 23, 2008 | 08:38 AM
udienow's Avatar
Brembo blanks will work fine with oem pads. I suggest going with hawk pads tho.
Old May 23, 2008 | 08:40 AM
ROCKART's Avatar
wants an I35
i had a brembo blank setup with Akebono SP ceramic pads. worked ok, very little dusting but not the stopping power i had imagined.
plus those brembos rust instantly after the first rain. i would either just get autozone generics ($12) or spend $80 each for zinc plated/slotted rotors.
brembo blanks are not worth it imo.
Old May 23, 2008 | 10:28 AM
maxx0831's Avatar
yeah they work fine.. I actually have Brembo blanks all around with hawks
Old May 23, 2008 | 11:27 AM
IlyaK's Avatar
The Golden One
I use Brembo Blanks and KVR Pads ONLY. That is my combination until further notice. I'm on my second set now and I love them.
You can get the pads from Alamomotorssports.com
Old May 23, 2008 | 07:06 PM
xenomax's Avatar
just paint the brembo blanks before you install them. it will help with the rust.
Old May 24, 2008 | 12:15 AM
CMax03's Avatar
If you don't like the rust...remove the rotor and clean the hub area with a drill or diegrinder equipped with a wire brush. Remove as much rust as possible. Clean and dry, then apply rust inhibitor. This rust inhibitor will turn that rusted area black. You then simply wipe down with a damp cloth, either paint or leave it bare! It should take 4-5 yrs b4 you see any rust on those treated areas again!
Old May 27, 2008 | 06:48 PM
joew's Avatar
thanks for the info. i don't like rust looking rotor. what is your opinion on autozone blank. does anyone know the prices on oem rotor.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
knight_yyz
Nov 1, 2015 01:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
