parking brake light and trunk
Old May 22, 2008 | 08:36 PM
polvoronn's Avatar
A little while ago the parking brake light wouldn't come off even when the brake level was all the way down. This would fix itself after several minutes of driving, but now it just never turns off.
Also, the trunk no longer opens when I'm using the remote or the trunk button inside the car. It will, however, open if I used the key.
Can anyone point me in the right direction with these two items? It never really bothered me before, but I'm wanting to replace my car with something newer and I might have to put the maxima on the market.
Old May 22, 2008 | 09:03 PM
ZX9RBART's Avatar
Your brake fluid is low.
Old May 22, 2008 | 09:08 PM
ZX9RBART's Avatar
And check fuse number 37 for the trunk.
Old May 22, 2008 | 09:16 PM
AEMAXIMA01's Avatar
Or your trunk is locked out, hence why it only opens with the key. There is a "switch" in the locking mechanism where it latches that can be moved up and down to lock out the trunk. Check there.
Old May 22, 2008 | 09:19 PM
ZX9RBART's Avatar
Good call, i forgot all about that.
Old May 23, 2008 | 07:17 PM
polvoronn's Avatar
Awesome! That has isolated the area that needs work. I think a screw might not be tight enough or something.
I'll try out the brake fluid later this evening. Thanks guys!
Old May 23, 2008 | 07:43 PM
ZX9RBART's Avatar
I would not add brake fluid unless you have a leak. The fluid "goes" nowhere so if it is low it means your brakes are worn and the fluid is in the calipers behind the pistons which are extended to apply the worn out pads. Replace the brakes and the pistons will be depressed back into the calipers refilling your brake reservoir
tsi6001
Oct 3, 2022 10:23 PM
Sport
Jul 3, 2017 05:40 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
