1995 with 1999 power seat...problemm
Old May 24, 2008 | 07:42 PM
maxkid123's Avatar
ok i just got a power seat for my 95 se and i pluged everything in and turned the car on and the seat wasnt moving....has anyone had problems with there power seats with maybe the motor going or sumthing???any hellppp would be greattt
Old May 24, 2008 | 07:48 PM
f550maranello2's Avatar
did ya check the fuse and or relay???
Old May 24, 2008 | 08:15 PM
maxkid123's Avatar
which fuse is it that powers the seat??
Old May 24, 2008 | 11:28 PM
deadmax96's Avatar
Originally Posted by Nopike
Heated seats is Fuse #29 (10 AMP) under the dash. You will need switches to turn these on.
Power seats use Fusible link (f) under the hood and Circuit breaker #1 located under the dash.
forgot where i found it
Old May 25, 2008 | 09:44 AM
IlyaK's Avatar
The Golden One
As I reply'ed in your PM...check the wiring too.
This is my seat that he bought and it works. It's either your wiring or your fuse(s). I believe the passenger side is wired for power too...try that as well. If it works there that means your wiring on your driver side is bad.
Old Jul 2, 2008 | 09:13 AM
ncross's Avatar
same problem
I got some new power seats and they do not work, I can't find the fuse under the hood that works, and I talked to a tech he said that the CB never go bad. What else could it be, and how hard is it to add another power wire to the seat, and run a new fuse?
Old Jul 2, 2008 | 12:36 PM
deadmax96's Avatar
first thing to check to see if motor is bad is just like ^. or you can do the old method......two wires a battery and just play with the plug or try to hook the wires up to the motor and see what happens directly. if not that check the lines to see it power is coming from them (power tester). Other than that just check the fuses and or relays.
Old Jul 2, 2008 | 03:53 PM
Armelius's Avatar
Bang that motor a little bit like you would hit a starter. Should be working after that if it isn't something else.
Old Sep 29, 2008 | 02:34 PM
eightball's Avatar
As long as we're talking about power seat problems; my 95 Maxima driver's power seat goes back and forth and the back cushion reclines and goes up fine too.
Problem: The seat cushion will not go up or down or tilt up or down.
If I get out of the seat, the cushion will tilt up and down, and also go up and down, but if I sit down on the cushion(put my body weight on it) when it's elevated it will drop down to the bottom position.
It almost sounds like some gear teeth rattling or grinding against some cogs when it goes down with my weight?
Would really appreciate some help. Is it some stripped gears, or what?
Old Sep 29, 2008 | 03:19 PM
internetautomar's Avatar
mod or sell?
sounds like stripped gears to me
Old Sep 29, 2008 | 06:03 PM
Agreed, or a very, very weak motor just about to die.
Old Sep 30, 2008 | 09:11 AM
eightball's Avatar
What would I being considering, parts-wise and labor time if I fixed it myself?
Are stripped gears part of the motor, or separate from the motor assembly?
Old Sep 30, 2008 | 01:19 PM
njmaxseltd's Avatar
Umm go on a diet perhaps?
Sorry, I had to.
Old Sep 30, 2008 | 03:54 PM
eightball's Avatar
Sorry, I had to.
When I wrote that first post, it crossed my mind that someone would have a witty retort/comeback when I said it/seat wouldn't lift my weight.
Old Oct 1, 2008 | 07:42 PM
mod or sell?
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
