rpm gauge
Old Jun 2, 2008 | 05:40 PM
99maxeclipsemtx's Avatar
rpm gauge
once in a while my rpm gauge goes all the way up and gets stuck there. and most of the time the gauge drops down like the car is off but if i pound on the dash real hard it pops back on has anyone else had this problem
Old Jun 2, 2008 | 05:51 PM
black_maxed95's Avatar
may have a loose connection. take your gauge cluster out and check the screws that hold the tachometer to the gauge cluster.
Old Jun 2, 2008 | 06:20 PM
fat_kid's Avatar
had this problem with my speedo, i just bought a new cluster and replaced it. could be a loose connection or could need a new tach gauge but if it doesn't really bother you, i wouldn't replace it.
and 300 posts
Old Jun 2, 2008 | 06:49 PM
QNO_A32's Avatar
just keep punching your dash.......
Old Jun 3, 2008 | 02:09 AM
cedric's Avatar
Looks like a dry joint. Remove the gauge cluster clean the connectors and try. If this fails, take the RPM meter out and re-solder the connections at the back of the meter.
Do not adjust the variable resistors.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
