weird accel problem
Old Jun 9, 2008 | 08:17 AM
udienow's Avatar
weird accel problem
Not sure how to describe this, but it started about a week ago. Sometimes when accelerating my car basically feels like it turns off for a split sec. RPM's drop, car stops accelerating, you can feel it as u kinda lunge forward from the sudden loss of acceleration, almost like im having fuel cut off. Its as if Im on the throttle, completely let off, then instantly get back on it again. Then it continues to accel normally again, sometimes does it again other times doesnt do it again for a while. It randomly does it at any throttle position. Sometimes it doesnt do it at all. It seems its more of a problem during/after rain. Last few days its been raining here and I've been noticing this problem more.
I've changed the fuel filter and spark plugs so far since I had to anyway, but problem still occurs.
My CEL went on the other day for P0440 (evap system crap) but I cant c how that is related. No other codes.
I couldn't really search since I didn't know how to put my problem into words to begin with... any ideas?
Old Jun 9, 2008 | 08:22 AM
pmohr's Avatar
No more Maximas...
Sounds like you're describing a misfire
Old Jun 9, 2008 | 08:42 AM
ruckus1027's Avatar
oh dude you're in luck ive had this plaguing problem before....it was like a couple bad coils....it was exactly like that...where im accelerating fine then for split second itll completely lose power and then kick back on...feel almost like jerking coz mine would do it twice...once on 2500rpm then 3000rpm...you might want to check coils..do a resistance test on them...does it idle funky?
ps im in illinois too! lombard, we can do swap coils just to check if you want...
Old Jun 9, 2008 | 08:51 AM
Snypa's Avatar
The last time that happened to me,for some reason, my fuel filter was badly clogged and that somehow fixed it.Check your FF.
Old Jun 9, 2008 | 09:01 AM
black_maxed95's Avatar
ya you have a 99 so its most likely your coils.
Old Jun 9, 2008 | 09:03 AM
pmohr's Avatar
No more Maximas...
Looking through his past posts he indicates that he has a '98
Originally Posted by udienow
Hey all,
I have 95k miles on my 98 max.
Old Jun 9, 2008 | 11:01 AM
udienow's Avatar
Spark plugs JUST replaced... hmm might indeed be coils as one had some oil on it....
Sounds good, its hard to just test it as it does it at random times, it doesnt always happen and has happaned at various RPM ranges and throttle positions. I'll PM ya or somethin. If it is coils, I have an idea which it may be.
I JUST replaced the Fuel Filter... i doubt thats it... unless i installed it backwards?!? Fat part up... right?
Negative, I have a 98... as previous poster said... i thought my sig would explain that so I didnt put it in the post. It has 123k miles on it now.
Old Jun 9, 2008 | 11:08 AM
pmohr's Avatar
No more Maximas...
Ah, so that pic in your sig actually does say something.
It looks like unintelligible text.
Old Jun 9, 2008 | 11:21 AM
clive's Avatar
100% chingon
........ It randomly does it at any throttle position. Sometimes it doesnt do it at all. It seems its more of a problem during/after rain. Last few days its been raining here and I've been noticing this problem more.
When a fault occurs more during rain, I suspect electrical systems, particularly high voltage areas so the suggestion to check coils is a good starting point.
Checking the primary resistance of a coil is useless, it tells you nothing.
Unless you have access to a HV insulation tester capable of generating 1000V test, I suggest taking the car to a garage with an engine analyser and take a look at the waveforms on the spark plugs. Any suspect insulation will show up as a reduced voltage peak.
Old Jun 9, 2008 | 12:05 PM
udienow's Avatar
Haha yeah the text on the left says 98NISSANMAXIMA
Even the text in the top left says things, its like car dimensions and stuff... not sure since my friend made the sig.
Anyway I guess I will start with coils.
Old Jun 9, 2008 | 12:24 PM
pmohr's Avatar
No more Maximas...
I see manufacturer code: 9259 (no idea what that means)
Wheelbase, overall length, curb weight, cargo capacity, seating capacity, front headroom, front legroom, and at the bottom '3.0L V6 190HP'.
Basically a lot of useless information, IMO.
Old Jun 9, 2008 | 12:30 PM
udienow's Avatar
haha yeah its useless, thats y its small and hard to read... just there to take up room and look neat i guess...
I will have a new sig soon anyway as this ones like 2 years old. As soon as my friend makes me a new sig.
Old Jun 9, 2008 | 04:40 PM
jordandalley's Avatar
car overheated recently? did you flush your radiator recently without waiting for the car to cool first? If so then maybe warped head? Can cause a lot of this surging you're describing.. feels a bit like misfires too. I hope for your sake its coils because theyre a bit cheaper. Coils are easy to check too
Old Jun 10, 2008 | 11:40 PM
izik's Avatar
you know its probobly just vapor lock; see if your fuel cap is on properly, if it is then just get a new one. that should fix the problem.
i've had this problem before.... dont wory its a cheap quick fix
Old Jun 11, 2008 | 07:15 AM
udienow's Avatar
Car has had no problems with overheating at all.
hmm.. what makes sense is the code I have can be due to a faulty fuel cap... i wonder how correct you are. I guess no harm in replacing the fuel cap, i'll do that.
Old Jun 11, 2008 | 07:46 AM
95maxdvt
Wouldnt seem it would make it run that ****ty from a faulty cap code???
I've heard don't hold me to it lol, but tighten cap n reset ECU???
ruckus1027's Avatar
hey dude i got the 0440 evap code too! i just found out yesterday...well if you buy a gas cap lemme know how much it cost...btw if you wana do that coil swap it would have to be soon coz im going to texas for two weeks..im leaving sunday...
Old Jun 11, 2008 | 07:51 AM
95maxdvt
Has anybody seen the 1006 evap PCV code??
ordered new PCV looks easy enough $8 part
wondering if this code is caused from 1005 EGRC Solenoid??
both parts are on the way courtesy of pinnacle nissan so i guess we shall see.
Old Jun 11, 2008 | 08:27 AM
ROCKART's Avatar
wants an I35
i had code P0440 (0705) and it was tripping the CEL. i tried the gas cap thing but that is a load of bs.
it didnt affect performance AT ALL. it is purely an emissions thing.
i ended up spending 110 for a whole new cannister and it fixed the problem
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
