Dash Cluster Lighting..
Old Jun 21, 2008 | 02:10 PM
  #41
arrocha87's Avatar
lol its broken enough....
Old Jun 21, 2008 | 03:20 PM
  #42
2da mizzax's Avatar
if you are cafeul you dont have to remove the sterring column sleeve. dont forget to pop your switches out from behind before trying to take off the black bezel.
Old Jul 26, 2008 | 03:40 PM
  #43
maxprivate's Avatar
Black Lion
Originally Posted by IlyaK
It's going to work simple. The 95-97 Maxima's odometer gets it's lights from the other gauge lights...so you still need 5. Once you put in 5, you'll have the same color odometer as the rest of the speedometer.
I had a 97 before this 99...so I know both speedometers and how they turn on/work.
Here is my 97 with VLED 194 LED bulbs (inverted):
I like that color of your leds. Where did you get these from?
Old Jul 27, 2008 | 03:07 PM
  #44
travis10302's Avatar
i want that for my car
Old Jul 27, 2008 | 03:08 PM
  #45
so do those blue 194 inverted LED bulbs just plug in?
Old Jul 27, 2008 | 03:11 PM
  #46
maxprivate's Avatar
Black Lion
YES the 194 go right in to your stock gauge lighting sockets. Im a 97 so I know I use 194.
Old Jul 29, 2008 | 03:07 PM
  #47
so are the inverted or the regulare V-LED's Better? and is it the 194, or the 74's that I need, and, last question, where do i get them from?
thanks.
sorry im such a newb
*edit* i have a 97' maxima SE if that helps
Old Aug 5, 2008 | 04:37 PM
  #48
maxprivate's Avatar
Black Lion
thanks.
I would also like to know where to get them , I guess search on ebay. Do you guys know if 15 deg viewing angle for leds are sufficient enough to light the needles well?. Im thinking of picking up white 3mm 14000 mcd from cwithk from Ebay. He's going to send me free resistors with the leds but I want to make sure these will last and be bright enough. The first time I installed leds behind the needles I used 3mm 5000mcd and they weren't that bright at all. And 3 of them went out after a few months I wonder if its because I didn't use diodes that they burned out in a short period of time.
Old Aug 5, 2008 | 05:02 PM
  #49
G4nismo's Avatar
anyone know the bulb size for the turn signals in the gauges?
its for a 97 gauge cluster.
i don't think its #74 b/c i compared one and the bulb in the turn signals and the 74's are a bit smaller
Old Aug 5, 2008 | 05:10 PM
  #50
maxprivate's Avatar
Black Lion
I also have a 97 and what I did with mine was remove the socket and solder a led to the + and - copper conductors there. Worked like a charm. If you look closely at the how 2 you will notice he has leds solders in place of the turn signal bulbs.
Old Aug 5, 2008 | 05:38 PM
  #51
Coolsaber57's Avatar
One question here:
In my 96, if I put white smt LEDs behind the cluster, how blue will it be? Slightly blue? Or blue blue? Does anyone have any pics so I can compare?
Old Aug 5, 2008 | 06:05 PM
  #52
G4nismo's Avatar
yeh, thats how i have my setup right now. thing is it would sometimes come loose and are hotspots. so i just wanted to get the correct size bulb and replace it
Old Aug 5, 2008 | 06:37 PM
  #53
maxprivate's Avatar
Black Lion
comes loose it shouldn't as long as you soldered it in place well. Once I set mine they never moved. The one thing I did notice with it is that you have to make sure the led is pointed dead center in the opening or it would not be as bright. But that only requires simply moving the led with your fingers till its dead center then put the dash in place and check.
Old Aug 5, 2008 | 06:56 PM
  #54
maxprivate's Avatar
Black Lion
Originally Posted by Coolsaber57
One question here:
It most likely will be a slightish blue hue to the white. I don't know if you have ever seen the hyper white polarg bulbs behind the gauges. Very slight bluish white. But these Smt hard to say.. the intensity might be much higher and more whiteish. So its really hard to say.
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
