new help. instruction how-to REPLACE STARTER
Old Jun 16, 2008 | 09:48 AM
ikalinin's Avatar
does anyone have a diagram, replacement instruction on how to replace the starter on a 1999 Maxima SE ? any help if appreciated.
thank you.
Old Jun 16, 2008 | 10:04 AM
CRiME's Avatar
oem ftw!
i followed these directions when i did mine:
http://www.motorvate.ca/mvp.php/516
larger pictures that might help are here:
http://forums.maxima.org/showthread....ht=starter+how
you have to have a breaker bar to put over your ratchet or you will not be able to break the starter bolts loose.
Old Jun 16, 2008 | 10:05 AM
ikalinin's Avatar
i just saw that thread..
thank you much.. i think this will be enough.
Old Jul 1, 2008 | 02:46 PM
Dice K's Avatar
Thanks for the link.
Old Jul 7, 2008 | 01:42 PM
bratfry's Avatar
I had to replace mine in a parking lot last Sunday(7/6). Its not real hard...BUT I got a starter from a local parts place (Bosh), it looked the same but was a bit shorter. They said it was ok... Didn't engage the flyweel. Went to Autozone and checked their rebuilt, it used a Nissan case, this one worked.
Make sure the replacement is exactly like the original. Unless you want to change it 3 times....
Old Jul 13, 2008 | 03:03 PM
sergiovv's Avatar
my maxima 95 sometimes doesnt do a thing just a click click when i turn it on but after 2 or 3 turns it will start normally sometimes starts at the first turn,,......and also the starter does not make any weird noises . i have read that could be the starter so i am going to clean it following the instructions in here and see what happens.
Old Jul 13, 2008 | 03:20 PM
CRiME's Avatar
oem ftw!
I had the same problem. THe greasing helped, but it only lasted for about a month and then I was back to the random, unpredictable click-click-click of death. No problems since I replaced it.
Old Jul 13, 2008 | 03:49 PM
99BlackMaxMS's Avatar
Yes, you do...that 17mm bolt in the back is a real PITA.
Old Jul 14, 2008 | 12:59 PM
bhunter's Avatar
I did mine last Thursday night in the parking lot of Papa Murphy's. Didn't need a breaker bar because I was pi$$ed.
Old Jul 14, 2008 | 01:17 PM
ajcool2's Avatar
Old Jul 14, 2008 | 06:40 PM
sergiovv's Avatar
oh ok thanks for let me know that.... i was undecided i think i will replace it then.
vingodine
45
May 21, 2016 12:46 PM
Slamrod
Apr 10, 2016 05:24 PM
doctorpullit
Oct 11, 2015 10:28 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
