door panel removal
Old Nov 4, 2001 | 10:46 PM
jay_johnson's Avatar
door panel removal
I need instructions for removing the front and rear door panels. I am planning on customizing the leather inserts in the doors, with reshaped, vinyl inserts. thanks....
for the record.... i did use the search... just couldn't find what i needed
Old Nov 5, 2001 | 12:19 AM
Nismo's Avatar
front- remove the little plastic handle piece -1 screw, remove the 2 screws on the bottom and then try to pull the panel off since they are held by some snaping clips. It is somehow hooked on where the window is so you might need to wiggle it a bit(at least I had to). you might want to roll the windows down to make it easier.
rears are just held on by snaps so just pull it off
Old Nov 5, 2001 | 04:20 AM
Thanks a lot buddy. I'll keep everyone updated.
Old Nov 5, 2001 | 03:51 PM
kmax's Avatar
Re: door panel removal
I think the inserts are plastic (from the factory)
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
carid
Sep 17, 2015 05:00 AM
