how do i get rid of the air bag blinking light....i have a 99 maxima!
Old Jun 26, 2008 | 08:13 PM
The Russian's Avatar
i just did the cool led gauges, and now the air bag light is more then ever annoying....i already stopped payin attention and now ...it blinks non stop...blah. i tried the key on, dooor button thing 3 times, then start....but it didnt work....also i have a 1999 with the airbags in the seat too....how can i get rid of the stupid blinking....i even wantd to just take hte bulb out...but there is no bulb its like blocked off w/ a plastic thing on the back of the cluster.....any advice?
Old Jun 26, 2008 | 08:49 PM
99BlackMaxMS's Avatar
Check all connections underneath both the drivers and passenger seats. When mine came on it was a loose harness/clip from under the passenger seat.
Old Jun 26, 2008 | 08:51 PM
pahaf's Avatar
jk, but like 99blackmax said, check all the connections, see that its plugged in.
Old Jun 26, 2008 | 08:52 PM
First the MAF, now this.....
When did your airbag light first start blinking? After a mod by chance?
Old Jun 26, 2008 | 09:08 PM
the maf accually wasnt bad, and it wasnt my fault, i went to get tune up, and make sure everything is good....and i guess they snugged on the wire too hard, and the power came out of the connector, and i went an hour and a half drive to hayward to find the connector....all fixed and like new....
not a mod, i connected a cop thingy.. lol =] hope no police are on this website...i had it and was bored so i connected it for fun, has the sirens, and loudspeaker....and i tucked it under the seat...i wonder if something disconected...!
Old Jun 26, 2008 | 09:10 PM
I bet that after "tucking it under the seat" you loosened a harness or a connection. Make sure everything is nice and tight and report back to us.
Old Jun 26, 2008 | 09:13 PM
and i had it blinking for a while...i thought a fuse went out on somthing...
Old Jun 26, 2008 | 09:14 PM
i looked....everything looks pretty fine to me.....any plug i should loook at in particular....i know its not the power one, nor the heated seat one.... also...how would that set off the air bag light
Old Jun 26, 2008 | 09:17 PM
Exactly why I asked!! Let's hope it's this easy and we figured it out.
Old Jun 26, 2008 | 09:19 PM
Look at the yellow plug.
A disconnected air bag plug is the same thing as a bad/blown airbag in the computers eyes...gotta check it thoroughly.
Right at the front of the seat cushion there is a metal plate with two plastic clips that allow a harness to attach to the plate. There are two YELLOW connectors (one running from the left and one running from the right) that connect at this metal plate. Make sure those are intact and snug, as I knocked one loose when vacuuming once and set off the airbag light.
Old Jun 26, 2008 | 09:21 PM
thanks, will check it 2mrw!
Old Jun 26, 2008 | 09:33 PM
UkiSash's Avatar
There is a way to reset that light.
I have the same problem and should probably figure it out.
Theres a sequence that you gotta do which includes locking doors turning the key in a certain position and clicking the door light switch 10 times.
cheftoo
Aug 20, 2015 05:17 AM
Samedi
Aug 13, 2015 04:05 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
