Can i redo my own brakes?
Old Jul 9, 2008 | 04:16 PM
Slitfang's Avatar
I need new caliphers, pads, and Rotors. Is this something i could do myself with some guidance or is it something that should be professionally done? btw i have access to a fully stocked garage w/ lift.
Old Jul 9, 2008 | 04:18 PM
black_maxed95's Avatar
if you got the space and tools its not hard at all. do it yourself
The only thing you dont have listed that youll need is someone to help you bleed the brakes when you are done.
Old Jul 9, 2008 | 04:35 PM
2da mizzax's Avatar
Do it yourself and ue the money to buy Hawk pads instead of some cheaper brand. We can give you some pretty detailed instructions.
Old Jul 9, 2008 | 04:42 PM
Jamaha80
Brakes are a good gateway job to become more capable of doing more intensive DIY repairs down the road (pun). Most jobs are "easy" as long as you have a good tool selection and time. It's important to have someone to help you bleed your brakes. I don't suggest the golf club between the seat and brake pedal while you go run to turn the bleeder screw method.
Old Jul 9, 2008 | 05:35 PM
B_Eaze's Avatar
if have access to garage tools u should b ok you can get speed bleeders if u need to do it urself. go to the advanced suspension and braking section for "how to" info
Old Jul 9, 2008 | 06:03 PM
internetautomar's Avatar
mod or sell?
it's all easily done by a rank amateur.
BTW what's a calipher? I know what a caliph is...
Old Jul 9, 2008 | 07:52 PM
z00york145's Avatar
I need to get new brakes, what do you guys recommend getting..I love the drilled and slotted ones, though I know their serious cash. What do most of you use?
Old Jul 9, 2008 | 08:17 PM
Crusher103's Avatar
u must love cracked rotors too
Old Jul 9, 2008 | 08:55 PM
maximase86's Avatar
I love lamp.
And lots of brake noise. The slots in my rotors are noisy.
S
Old Jul 10, 2008 | 12:16 AM
Snypa's Avatar
http://forums.maxima.org/4th-generat...ad-change.html
Old Jul 10, 2008 | 06:13 AM
mod or sell?
1. they aren't that expensive.
2. they aren't worth squat
3. Good pads and Blank rotors are the best option for regular street driving.
Old Jul 10, 2008 | 06:24 AM
B_Eaze's Avatar
drilled slotted rotors look cool
but for real, everyday driving better off getting brembo blank rotors
Old Jul 10, 2008 | 09:38 AM
Dooley's Avatar
+1 on the Brembo blanks
Old Jul 10, 2008 | 11:30 AM
mowgli29's Avatar
Horizontally opposed.
+1 on blanks. My drilled/slotted didn't crack for almost two years...but there are now visible cracks around the holes. Not to mention a Daily driver doesn't need the cooling or anything else from drilled/slotted. AND blanks have more surface area (IIRC about 12%!!) which means better braking!
Oh and get zinc coated ones to prevent premature rust.
I'd say DIY. Rotors and pads are not hard, especially with help from the org info. The only thing you might need help with is bleeding the brakes.
Also, I think there is a different bleeding procedure for ABS. Just a heads up if you have ABS, you may want to research that a bit.
Old Jul 10, 2008 | 12:16 PM
Slitfang's Avatar
This is awesome. What brake pads calpers and rotors would u guys reccomend getting?
Old Jul 10, 2008 | 12:30 PM
ThurzNite's Avatar
I'm selling my used stock stuff, calipers, hardware, brakelines. You can rebuild the calipers, but they work just fine, they don't stick. Lemme know if you're interested.
http://forums.maxima.org/4th-generat...sp-manual.html
There's a guy named Jason in the group deal forums, he has pads and rotors for really good prices. Check him out.
Dr J
Old Jul 10, 2008 | 01:42 PM
mowgli29's Avatar
for performance, brembo blanks and hawk hps pads.
for low dust but still better than cheap pads, brembo blanks and akebono ceramic pads.
Old Jul 10, 2008 | 02:10 PM
z00york145's Avatar
how much do the brembo blanks run ya? I only said I love them because i think they look awesome, but if their garbage performance, screw them.
Old Jul 10, 2008 | 02:36 PM
mowgli29's Avatar
IIRC, rears can be found for about 30 each plus shipping. Not sure about fronts.
edit: check out this thread
or pm importrp for pricing.
Old Jul 10, 2008 | 02:39 PM
Slitfang's Avatar
could someone help me find good performance calipers? i want an equal measure of comfort and sport feel if possible. leaning more towards sports if necessary.
Old Jul 10, 2008 | 02:45 PM
mowgli29's Avatar
If I were you, I'd stick with stock calipers.
There are big brake kit options available, but they're expensive and not necessary for a daily driver. IMO a BBK in the front only would drastically alter brake bias and not result in shorter stopping distances anyway.
Invest your money in good pads and rotors. Maybe some SS lines if you want a more solid feel.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
