'96 Steering Loose Help!
Old Jul 12, 2008 | 08:34 AM
Altimat's Avatar
ActiveTuning Partner
My daughter's 190K '96 has a strange looseness in the steering where the center position of the steering wheel moves back and forth depending on road conditions. You can watch this happen by looking at the tires while going dowen the road. I inspected everything underneath (Ball joints, struts, tie rod ends) but cannot see any looseness. Whatever it is affects the entire linkage so it has to be a central problem in the column, rack, or rack bushings. Has anyone experienced this? TIA for any advice!
Old Jul 12, 2008 | 08:53 AM
knight71's Avatar
I had this issue at one time. My problem was stabilizer link bushings were shot. This is a common issue with our cars. Inspect these..chances are the bushings are ripped. The parts are not expensive to fix this.
Old Jul 12, 2008 | 01:42 PM
dgeesaman's Avatar
Maintenance Monster
Start with the steering rack bushings. They are the only element that would explain the wheel getting knocked off center and back again.
But while your'e in there inspect the control arm bushings, stabilizer links, and swaybar bushings too.
Old Jul 12, 2008 | 04:23 PM
Altimat's Avatar
Was hoping to not hear that it could be the rack, and was hoping that it might just be rack bushings. Thanks!
Old Jul 12, 2008 | 06:51 PM
matrix11229's Avatar
I have the same problem even after I replaced control arms , tie rods, sway bar endlinks and bushings.
Where are the steering rack bushings located and how hard are they to replace ?
Old Jul 12, 2008 | 07:32 PM
nyc96max's Avatar
do you mean the steering wheel moves left and right or steering wheel move up and down
Old Jun 20, 2009 | 10:02 PM
Mine moves up and down
Old Jun 21, 2009 | 08:13 AM
omoran2958's Avatar
i had that problem, ichanged the rack and pinion mounts,sway bar bushings and sway bar link bushings now it is perfect.....
D Mason
Jun 21, 2016 04:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
