Check engine light
Old Nov 6, 2001 | 08:18 AM
lscottjr's Avatar
Maxin in NY
Check engine light
I have a 96 Maxima (base model) with 95K miles. The car has been well maintained and usually runs pretty smooth. This past friday night I filled up the car with the normally gas that I normally use at the usual gas station that I go to (Super plus - Mobil). Saturday morning I start the car and the CHECK ENGINE light comes on. It does not blink or flash. It just stays solid. The car still starts up with no problem ans it seems to run fine. From the reading that I have done so far the problem could be a number of things (bad gas, emission problems, e.t.c). Has anyone out there has any experience with this.
Thanx,
Louis in NY.
Old Nov 6, 2001 | 09:44 AM
clee130's Avatar
Do an ECU check ... check the "ECU Diagnostic Trouble Codes" thread above.
Old Nov 6, 2001 | 01:22 PM
lscottjr's Avatar
Maxin in NY
Check engine light
I may not be able to fix the problem, but at least I know what it means.
Thanks,
Louis in NY.
Old Nov 6, 2001 | 01:27 PM
Sprint's Avatar
Re: Check engine light
Thanks,
Louis in NY.
well as soon as you find out the code.. check that thread.. it has great pointers to fix all those things.. pretty basic information for the avg person
Old Dec 11, 2001 | 01:29 PM
froggy3132000
same thing
the same thing happened to me this weekend, i put a full tank of 93 at Mobil and the next morning the check engine light came and has been on ever since. but the car is running fine, Any suggestions?
96' Max GLE
Old Dec 11, 2001 | 01:36 PM
clee130's Avatar
Re: same thing
Yes ... do an ECU check.
96' Max GLE
Old Dec 12, 2001 | 08:57 AM
cleanmax02's Avatar
The same thing happened to me a while back. The light was on for a while, but the car started and was running fine so I eventually took it into the shop and they said the "nock sensor" (sp?) went bad, and they had to replace it. Since the car has 95k on it, it could be that a sensor went bad, but do get the ECU check.
Old Dec 16, 2001 | 08:32 PM
GTRBlkMax97's Avatar
How much did that cost you?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
