A/C smells bad, I tried Lysol, something's not right!
Old Jul 19, 2008 | 12:32 PM
curiosul's Avatar
There are several posts/threads about this problem/solution. I also have a smell so I just tried it. Some things were weird:
1: While the fan was at the maximum, there was no noticeable air suction through that grille
2: After (and during) spraying, there's no Lysol smell in the car
3: There's no grille on the passenger side of the car
I tried the same thing in my 98 Civic and there it worked like magic.
Any ideas? Is there any other air intake?
Thanks in advance!
Old Jul 19, 2008 | 12:44 PM
Jamaha80
through that grille
What grille? The front/hood grille?
Where are you spraying? Through the hood grille??? ROFL.. Please say "no."
I am so confused... If you are referencing steps taken from a different thread, try referencing it with a link...
Old Jul 19, 2008 | 12:56 PM
curiosul's Avatar
That's the thread:
http://forums.maxima.org/3rd-generat...ditioning.html
The grille under the windshield (just as described in that thread).
Old Jul 19, 2008 | 02:41 PM
SVI30's Avatar
Frequently that small comes from using recirculation mode too often. You want to use outside air as normal and recirculation sparingly.
The car takes in outside air from the grill in front of the windshield but it takes in inside air (recirculation mode) from an opening on the passenger side behind the glove box.
Old Jul 19, 2008 | 04:09 PM
d1max2nv's Avatar
Thanks in advance!
the grill is on the driver side under the wiper, make sure the circulation button is off, and it works better if you run the heat while doing this...
Old Jul 19, 2008 | 04:30 PM
QNO_A32's Avatar
mine wasnt bad at all but i just used some stuff the other day, its a BG product and worked awesome.
Old Jul 19, 2008 | 04:45 PM
CRiME's Avatar
oem ftw!
take out the glove box, open the large black box that contains the evaporator core and hit the evaporator with the lysol.
Your evaporator probably looks like the one in this thread:
http://forums.maxima.org/4th-generat...vaporator.html
Old Jul 19, 2008 | 05:08 PM
curiosul's Avatar
d1max2nv: I did exactly that except the heat thing - I'll try it tomorrow.
crime: I'll try that in case I can't fix it OR if I fix it but the smell shows up quicker than I expect.
Thanks for the ideas!
Old Jul 20, 2008 | 07:17 PM
sparky1562's Avatar
This is what mine looked like this morning. AC works great now!
Attachment 627
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
