Code p0420
Old Jul 19, 2008 | 03:56 PM
d1max2nv's Avatar
Code p0420
I changed my cat out for a high flow one about 4-5 months ago now I am getting a code p0420 catalyst efficiency below threshold (bank1). Someone said it might just be my oxygen sensor could it be? thanks for any help guys.
A. Gokool
Old Jul 19, 2008 | 04:06 PM
pmohr's Avatar
No more Maximas...
It could be an O2 sensor, or the cat itself could be bad.
It wasn't one of these style HFCs, was it? Those are nothing more than resonated test pipes...
Old Jul 19, 2008 | 04:09 PM
S14-NEO's Avatar
best way to tell is to use consult and graph both of the o2 sensors, that will usually tell you if the Cat is bad or is the o2 sensor is bad. the bad thing is you would have to goto nissan or something like that to communicate with your ECU that has the ability to data monitor .
Old Jul 19, 2008 | 04:11 PM
d1max2nv's Avatar
well It wasn't one of those e-bay cats, my buddy owns a muffler shop and did it for me. will this damage anything on my car?
Old Jul 19, 2008 | 04:13 PM
d1max2nv's Avatar
I just looked under the car and it looks something like that one in the pic...
Old Jul 19, 2008 | 07:34 PM
Snypa's Avatar
Did you have a light before the new stuff.?
Old Jul 19, 2008 | 07:52 PM
99BlackMaxMS's Avatar
I had this code intermittently while the car was bone stock (minus the intake). It ended up being one of my downstream O2 sensors. It never hurts to replace those if they haven't ever been done.
Old Jul 20, 2008 | 01:35 AM
d1max2nv's Avatar
NO i didnt. but it goes on and off.. Like if I run the car really hard it wold cut off and say off for a day or 2 then pop back on and the car starts to drink gas....
Old Jul 20, 2008 | 08:34 AM
maximized98's Avatar
Addicted to the Org
You need to get an o2 simulator for your downstream sensor.
Old Jul 20, 2008 | 02:01 PM
vilmaxima's Avatar
Heres your easiest way to tell. Put back your old cat if no CEL comes on, then its the test pipe/resonator. If CEL still comes on its your sensor. I bought one of these but decided not to put it on, maybe Ill try it out at the track(the supposed 5-10hp gains they advertise).
Old Jul 20, 2008 | 02:31 PM
d1max2nv's Avatar
whatsa 02 simulator?
Old Jul 20, 2008 | 02:32 PM
d1max2nv's Avatar
oh the power is there with the test pipe. **** moves...
Old Jul 20, 2008 | 02:43 PM
Addicted to the Org
It's a 3 wire circuit board that will tell the computer that everything is ok. The o2 sensor before the cat is for the air/fuel ratio, the sensor after the cat measures the amount of oxygen that passes through the cat. If the rear sensor is reading the same amount as the front sensor, then it throws a code because the cat is not doing its job.
Old Jul 20, 2008 | 05:50 PM
d1max2nv's Avatar
I see I see and where can i get one of these?
Old Jul 20, 2008 | 06:47 PM
Addicted to the Org
O2simulator.com 40 bucks shipped.
Old Jul 20, 2008 | 06:56 PM
QNO_A32's Avatar
where could someone get a "decent" test pipe at ? if thats even possible..... flanged 2.5 FTW????? i would hate to get one off ebay.
Old Jul 20, 2008 | 08:23 PM
d1max2nv's Avatar
thanks..
Thanks for all your help guys..
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
