Is it save to drive on 2 strut screws ?
Old Jul 25, 2008 | 12:39 PM
xkazik's Avatar
So while putting on my strut bar my step dad decided to help me with tithing the screws and he twisted one off . now my question is , can i drive like this ? or do i need a who new strut? Are the 3 screws part of the strut or is it a separate park ? if so what is it called ?
Old Jul 25, 2008 | 12:59 PM
Bearkat's Avatar
No, it's part of the strut mount, it can be replaced but you have to disassemble the strut assembly. I'm pretty sure it would be ok to drive on, it just will put 33% more stress on the other two bolts. The bolts and nuts themselve can be bought from NAPA. They look like the bolts that your wheels bolt onto.
Old Jul 25, 2008 | 08:42 PM
Nopike's Avatar
You'll be fine for a while, just take it easy with the car. You will need to change the strut mount. If you are going to change the strut mount you should consider changing the struts if they have like 60-80K miles or more on them. The strut mounts wear anyways so it's not a bad idea to change them. Don't forget the strut bearings. If he torqued it so much that it broke it may have been "weak" anyway.
Old Jul 25, 2008 | 09:00 PM
maximase86's Avatar
I love lamp.
Be sure you don't over torque the nuts. You might be able to take the assembly and replace the stud, but it's probably better to replace the mount.
S
Old Jul 26, 2008 | 04:00 AM
B_Eaze's Avatar
Like everyones' saying, might as well change the struts. It might not be a bad idea to get one of these too: (click stop)
http://www.harborfreightusa.com/usa/...submit=find+it
the part you need is in the stickies: (Part# 54322)
http://forums.maxima.org/4641348-post4.html
Old Jul 26, 2008 | 09:50 AM
xkazik's Avatar
yea man im differently getting one . already looked . i guess i wait till i save up enough to change all 4 struts and some lowering springs .
Old Jul 29, 2008 | 09:42 AM
robsst's Avatar
If you use the Haynes manual for instructions on replacing the struts/strut mounts, read the torque specs CAREFULLY. The torques for the strut mount nuts is in in/lbs, not ft lbs (Big Difference).
I wasn't careful, made a mistake, and ended torquing the stud right off the mount.
Best of luck!
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
Stelianos
Aug 24, 2015 12:13 PM
