help with greddy muffler sizes
hey im redoing my exhuast so i need some input. before i start i need to ask one question: i jacked up my car and saw it has 3 cats. is this normal!?
ok so i found an exhuast system i like. sounds BEAUTIFUL. the Greddy Ti-C exhuast. ( here's a link to what it sounds likes http://greddy.com/home/?id=222 ). since they dont make an entire system for the maxima, i am going to buy just the muffler and then go diff piping. first question is:
what size inlet do i need?? ( http://www.dezod.com/pd-greddy-ti-c-...al-muffler.cfm ) does a bigger inlet mean bigger muffler thereby increasing the deep tones of the muffler??
2nd: will different piping affect the sound alot?
3rd: what size piping would i use? i want to go catback
since your posting in the 4th gen forum i guess you have a 3 liter unless you have a 3.5 swap. you would need a 3.5 liter engine and equal length headers with 2.5 cat back to that muffler to even come close to that sound clip. good luck!
Ok, I understand your question. It wont sound like that. It may sound close, but that is a Z, not a max. Even with a 3.5 swap and equal length long runner headers, you still wont sound just like that.
black_maxed, its a Z with the catback.
Greddy makes a cat back system for the max.....SP2
http://greddy.com/products/display/?...&SubCategory=1
Check the exhaust stickies for sound clips
haha the sp2 sounds like ****. im gonna go with this muffler i think cuz its tight as hell and do my own mandrel bent piping. question: is the stock piping 2.5"? if not, would i have to change up the headers as well?
Install headers to do what in relation to 2.5" exhaust?
Certainly the turbo will affect engine wear. Do you really expect to add power and not increase wear? If you drive vigorously but with some respect for the equipment, you can expect about 90% of normal engine life.
As for the transmission and drivetrain being affected....
Very unlikely. Consider that the drivetrain endures more torque in first gear from the stock engine than almost any turbo can produce in second gear. Occasionally a clutch comes along that won't do the extra duty. Most clutch problems are going to crop up when shifting habits are less than acceptable.
Will the turbocharger affect engine wear and maintenance?
knight_yyz
11-01-2015 01:34 PM
