Can anyone answere this?
Old Aug 11, 2008 | 11:25 PM
MAXC's Avatar
Im pulling a code P1805 which says that its a secondary vacuum circuit malfunction. Cool. Now when i go to the 03 maxima FSM it says that P1805 is a "DTC P1805 BRAKE SWITCH???" Now I have a 97 max that is a FULL Swap from a 03 & started getting this code after some work was done to the Evap Sys. Im thinking that this code is somewhat related with the Evap but kinda puzzled on where to start looking cause im not throwing any more codes for the Evap. Anybody have any ideas?
Old Aug 12, 2008 | 02:21 AM
JonBlz's Avatar
a.k.a. STuNtMAN
did you put an aftermarket intake if so or even stock air box check to make sure all vacuums are connected
Old Aug 12, 2008 | 04:39 AM
goldtooth's Avatar
if you have the 5.5 gen ecu ('02-'03) which you do becuase of the full swap then you would go by the 03 FSM...
Old Aug 12, 2008 | 04:42 AM
goldtooth's Avatar
Double check the Brake switch just in case.(wouldnt hurt)
and double check that DTC code, you mentioned P1085 and P1805...
Old Aug 12, 2008 | 05:37 AM
maximabebe's Avatar
From reading the first post, he says that he referred to the '03 manual.
Old Aug 12, 2008 | 06:25 AM
goldtooth's Avatar
I know...
Old Aug 12, 2008 | 09:00 AM
MAXC's Avatar
I have a Place Racing CIA, All is connected.
I used the 02, 03, 04
Did it, It checked out fine.
my mistake, its a p1805
Guess he was being sure
I know...
doctorpullit
Mar 29, 2016 11:08 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
lrb6805
Sep 24, 2015 05:03 PM
msellas
Sep 23, 2015 09:16 PM
Keyno McMike
Sep 21, 2015 07:18 AM
