Having bolt removal problems
Old Aug 15, 2008 | 05:57 PM
hot_wax_tree's Avatar
I just recently bought a y-pipe and am wondering how I am supposed to remove my completly rusted over nuts and bolts. There is a layer of rust over them I am going to try to use some spray stuff but should I just get a big breaker bar or would that bust the bolt on there?
Thank you
Jake
Old Aug 15, 2008 | 06:19 PM
There is a product that you can put on the bolts overnight to loosen them up, but I forgot the name of the product. Someone will most likely post the name of it. Help me out here.
Old Aug 15, 2008 | 06:32 PM
thegoldenmax's Avatar
I would suggest spraying down the nut and bolts down with wd40 then get the handle off of your jack and then put that on the breaker bar and turn if anything breaks then you might need to drill the bolt out
Old Aug 15, 2008 | 07:22 PM
99BlackMaxMS's Avatar
I had to cut out the bolts between my muffler and b-pipe when I was installing my catback. Try and find a shop that will break the bolts for you. When I helped my friend install his rear-section on his 96, I brought it to a local shop and they broke the bolts for $15 dollars.
Old Aug 15, 2008 | 07:45 PM
B_Eaze's Avatar
i dont think WD40 can handle exhaust bolts. Liquid Wrench or PB Blaster let them soak on a cool exhaust overnight. or u can dremel the off (maybe?).
or a shop like 99MAX suggested
Old Aug 15, 2008 | 07:46 PM
Gismo-T's Avatar
B!tch We Got a Problem
The product that your probably thinking of is PB Blaster, stuff works great!
With you being up in Minnesota, they're rusted pretty bad. So either torch off the bolts or cut them off.
Old Aug 15, 2008 | 07:47 PM
Dhione's Avatar
I had to burn mine off, or i forgot the name of it but looks like a socket but it has thread in it that are used to get out striped bolts but i have used them for rusty bolts befor with some PB blaster sitting over night.
Old Aug 15, 2008 | 07:51 PM
That's the stuff. If that doesn't work then definetly burn, cut, or break them off. Good luck.
Old Aug 15, 2008 | 09:13 PM
KRRZ350's Avatar
Lol at some of the suggestions, because even if you can use any of the suggestions to loosen and grab them they are going to snap anyways. You have to cut them out and get it drilled or just have an exhaust shop clamp and tack it for $20.
Old Aug 15, 2008 | 09:16 PM
thank you so much for all of your suggesttions
I will try these suggestions and let you all know thank you again guys.
Old Aug 15, 2008 | 09:55 PM
hott_nikkelzz's Avatar
KRRZ350 is right...
best bet is to get a shop to heat them up and loosen them... otherwise get them to cut and install new ones... cheap to do.
Old Aug 15, 2008 | 10:42 PM
zim5004's Avatar
I Installed a y-pipe on my car And the place I took it to cut off the bolts and drilled through them and put a new nut and bolt on there and it works good.
Old Aug 16, 2008 | 06:34 PM
caseymaxima's Avatar
Just torch them off, but I would only torch the bolts where the Y pipe meets the cat, not the bolts on each bank of the engine. YOu can buy a small torch set up at home depot for about $40.00.
Zack
Old Aug 16, 2008 | 06:38 PM
j2b4osan's Avatar
if you use some krill oil and use a nice tight socket and take your time with steadily increasing pressure you can probably get them off no prob. its probably just flaky surface rust. Ive seen bolts that looked like they would disintegrate but when treated with care and removed correctly and cleaned they can often be re-used.
Old Aug 16, 2008 | 06:44 PM
B_Eaze's Avatar
Hey lives in Minnesota, doubt any exhaust bolts will be getting reused
Old Aug 18, 2008 | 12:17 PM
MatJ's Avatar
pb blaster or marvel mystery should help them a little. if you can get a good grip on them with a regular socket use one that is threaded for stripped bolt removal, iv got a set from snap-on but sears might have a set.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
dcam0326
Sep 18, 2015 04:52 PM
Colossus
Sep 9, 2015 05:46 AM
