fstb rubbing a/c pipe
Old Nov 7, 2001 | 04:19 PM
max808's Avatar
anyone notice this? what di you do to avoid rubbing. i'm thinking of putting a washer around the bolts to make it a little bit higher. any ideas?
Old Nov 7, 2001 | 04:30 PM
njmaxseltd's Avatar
Just move the mount for the A/C line over a bit and it will clear the FSTB.
Old Nov 7, 2001 | 04:34 PM
WaarrEagle's Avatar
Re: fstb rubbing a/c pipe
I have a FSTB and it touches the AC pipe but I didn't do anything about it. I dont think it rubs that much so I just keep an eye on it and if it starts looking bad I will do something.
Old Nov 7, 2001 | 06:30 PM
BRIGBOY's Avatar
I slid the balck foam cover over an inch.
So now it is between the FSTB and the pipe. I don't use the AC anyway, so it never really concerned me.
Old Nov 7, 2001 | 07:47 PM
apexi's Avatar
which FSTB do you have? the one i have only rubs on the hood liner!
Old Nov 7, 2001 | 10:16 PM
Solo950's Avatar
insulation
I have the same problem with my Courtesy fstb. I solved it by putting some pipe insulation around the ac pipe at that point. It provides a foam buffer, so the two don't rub at all. I attached a picture of my engine compartment, you can see the insulation on the left hand side. I hope this helps.
Old Nov 8, 2001 | 12:41 PM
apexi's Avatar
Re: insulation
does your courtsey bar rub against the hood liner?
Old Nov 8, 2001 | 12:48 PM
max808's Avatar
Re: I slid the balck foam cover over an inch.
i did almost the same thing. i put a old golf club grip around the a/c pipe, should be ok for now. i also put the same grip near the accelerator cables because the bar was touching it. the bar gets really hot and may melt the accelerator cabling.
Old Nov 9, 2001 | 08:38 AM
Solo950's Avatar
Re: Re: insulation
As far as I can tell, no. Looking at the liner, I don't see any indentations or signs of wear. I cannot be absolutely sure since I cant see under the hood with it down . How do you know that yours is rubbing?
Old Nov 9, 2001 | 09:34 AM
MDr's Avatar
MDr
Re: Re: insulation
Yes.
Old Nov 9, 2001 | 02:07 PM
bigxsimon's Avatar
Re: insulation
Originally posted by MDr
Yes.
when i first installed my fstb, there was no problem.. and jus last week, my service light came on.. turns out, the fstb broke one of the pipes/wires.. i'm not sure if it's the a/c.. i tried putting it back on today but no luck.. one wire is completely getting in the way and i can't move it over because it's pretty much attached.. any help is much appreciated..
Old Nov 9, 2001 | 03:16 PM
max808's Avatar
Re: Re: insulation
do you have any pictures showing where the broken pipe/wires are?
Old Nov 9, 2001 | 03:57 PM
apexi's Avatar
Re: Re: Re: insulation
theres an indentation on the hood liner + i painted my bar, and the paint is rubbing off in certain areas!???what so different about my bar, i got it from courtsey and i have a 4th gen?
Old Nov 11, 2001 | 01:33 PM
kmax's Avatar
A/C and hood liner
I put on a Courtesy strut bar yesterday, a day after reading everyones
comments about it rubbing against the a/c pipe and hood liner. After driving it hard this afternoon I do notice that the bar has left a mark on the a/c tube. The pipe insulation idea is worth a try.
I drew a line across the bar using lipstick (easy to get and cleanup, and dosen't dry)and checked the hood liner after driving for a while. There were two marks on the liner from the lipstick each about an inch long and located near the center and center passenger side. At this time I don't think that the bar hitting the liner is a problem.
The improvement in steering? Huge !!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
homewrecker
Sep 24, 2015 07:01 PM
