Lights not working???
Old Aug 21, 2008 | 02:51 PM
Madmax66's Avatar
Niether side clearance lights getting current, nor drivers side running light. Pass. side works. Fuse ok...had 10 amp in there from earlier clearance mod (tin foil) went to nip post on clearance bulbs to fix as foil wouldnt stay in place....can't get anything to work...or figure out whats wrong. Any suggestions?
Old Aug 21, 2008 | 03:47 PM
I don't know what it could be bro.
Old Aug 24, 2008 | 06:36 PM
jheaton's Avatar
Did you check the current with a multimeter or are you just guessing
Old Aug 24, 2008 | 06:38 PM
phatryan69's Avatar
well you might not be gettin a complete circuit try pulling the bulbs out again and check all the connections on it... might be a relay under the hood... check those things
Old Aug 25, 2008 | 11:44 AM
Madmax66's Avatar
I dont have a multimeter..just a simple test light. Dint think I have current. I got the marker light working. Got 2 new bulbs for clearance...nipped the nibs...still nothing on either side. 10 amp fuse ok. I was going to just tap into marker lights as theyre on the same switch and fuse...no clue why current not getting there.
Old Aug 25, 2008 | 11:47 AM
Madmax66's Avatar
Connections seem ok...I looked at relays but not that closely. I did tap into marker light for fog rewire. That was YEARS ago and theyre still fine. Maybe i'll take a closer look. And if not...just try the tap to marker lights.
Old Aug 25, 2008 | 08:07 PM
tony22ea's Avatar
wer can i find some fog lights for my 96 maxima?
Old Aug 25, 2008 | 08:26 PM
92gxe/cg2's Avatar
Irrelevant post...
But i would imagine an auto parts store would sell fogs or ebay, or the classifieds, just a guess tho.
jerrod99_se-l
Aug 27, 2015 08:27 PM
KristyKarina
Aug 23, 2015 09:53 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
