Weird smell when useing the turn signals
Old Aug 23, 2008 | 07:57 PM
phatryan69's Avatar
when i use my turn signals i get like this burning smell like its burning the wires but i cant find anything i have inspected almost ever wire that i can find and nothing any ideas???
Old Aug 23, 2008 | 08:47 PM
knight71's Avatar
Here is a possible solution to your problem:
http://www.motorvate.ca/mvp.php/600
Old Aug 23, 2008 | 09:12 PM
muravei2's Avatar
Blinker fluid low?
Old Aug 23, 2008 | 09:51 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
u might have to replace the stalk like others have suggested.... this happened to me ... everytime i turned on the lights or used the turn signals smoke came out and it smelled like burning rubber ..... there was a short in the stalk itself because some plastic piece melted/broke off ...
Old Aug 24, 2008 | 06:36 PM
phatryan69's Avatar
but i dont see smoke anywhere so i dont kno its really stumpin me i guess i could try and get a new one
Old Aug 24, 2008 | 06:43 PM
Nopike's Avatar
I agree with this post probably the cause of your problem.
Old Aug 25, 2008 | 12:07 AM
muravei2's Avatar
http://forums.maxima.org/4th-generat...rn-lights.html
Could also be related to this thread?
Old Aug 25, 2008 | 09:27 PM
phatryan69's Avatar
i have seen no smoke and its not from my steering wheel i didnt use my turn signals all day and didnt smell anything so i have no idea WTF is wrong i guess i might just have to find a new Switch???
Old Aug 25, 2008 | 10:26 PM
MorpheusZero's Avatar
Clearly your blinker fluid has absorbed water and the boiling point has come down significantly.
Blinkers dissipate lots of power, which both radiates (light) and convects/conducts (heat). You need blinker fluid that can handle that sort of heat without boiling, and just 1000 parts of water per million parts of blinker fluid can lower the boiling point by up to 200 degrees F.
Change out your fluid or flush the whole blinker hydraulic system and put in some silicone-based DOT5 stuff.
Old Aug 26, 2008 | 01:04 PM
IlyaK's Avatar
The Golden One
Originally Posted by muravei2
Blinker fluid low?
This was an unnecessary post, n00b. He obviously has done enough work to try to find his issue that he doesn't need BS posts such as yours. Keep that crap to yourself. Don't even bother with a comeback.
As for the problem, definitely try a different stalk. I have two if you want to buy one (no fog light switch though). I'll sell it to you dirt cheap since you really need it sounds like. Let me know.
$30 shipped to KY.
03VQMAX
Oct 2, 2016 09:36 AM
rtirbany
Sep 8, 2015 11:46 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
