canister purge control valve (10-08)
Old Aug 28, 2008 | 07:43 AM
rm4628's Avatar
CLICK CLACK 1
95 max auto CALI emmision! 145k. This code is kicking my *** 10-08 evap purge controlvalve circut. First off Hanes is no help, has limited info on part besides wiring diagram. Can't find a used engine with valve and valve does not exist on nissan oem connection. I' checked all hoses for leaks and everything checked out fine. Has anyone ever had this code on a cali emission or changed this part, trying to leave stealership out of this one. The stickies say this valve has a two wire connector but mine seems to have a six wire connection , any imput would help thanks.
Old Aug 28, 2008 | 12:24 PM
Nopike's Avatar
Can't say for sure from the code but you probably need to check the valve by the canister located under the trunk on the drivers side, that is a two wire valve. I don't believe this is located in the engine compartment if that is where you are looking. Should be plenty of write ups on this.
Old Aug 28, 2008 | 12:50 PM
rm4628's Avatar
CLICK CLACK 1
Thanks man your help is appreciated
Old Aug 28, 2008 | 09:25 PM
pmohr's Avatar
No more Maximas...
The code is for the EVAP CPCV, and it has a 6-wire connector.
Old Aug 28, 2008 | 11:27 PM
rm4628's Avatar
CLICK CLACK 1
Thanks for verification, i know i was looking at the right part
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
