idling problem
Old Sep 3, 2008 | 02:27 AM
JonBlz's Avatar
a.k.a. STuNtMAN
idling problem
okay i have had an idling problem since i did my 00vi in my 99 i just did a motor swap to an 01 AE with 40k and my car still idles high... heres the problem i be driving and when i push the clutch down when coming to a red light i throw it in neutral let it glide to the light and my RPMS shoot up to 1500-1700 rpms and then when i come to a complete stop then it goes back to normal idling around 750 rpms i need help with this i really wanna fix this now its annoying when im driving and my switch gears and my rpms shoot up high also so plz guys help me out
Old Sep 3, 2008 | 05:13 AM
njmaxseltd's Avatar
Many auto that were converted to manuals have that same symptom.
I would try to adjust the default throttle stop and the IACV.
To adjust the default throttle stop, the car must be at operating temp, TPS disconnected. Idle speed should be set around 600 - 650. Reconnect TPS and adjust the IACV until you abtain the correct idle speed.
The whole process is found in the Haynes shop manual.
Old Sep 6, 2008 | 11:15 PM
JonBlz's Avatar
a.k.a. STuNtMAN
i didnt have that problem when i converted it to stick it happened when i did the 00vi and is still doing it after i did the motor swap as well
Old Sep 6, 2008 | 11:41 PM
GStrength's Avatar
that same issued occured when i stilled my mevi, but then again it happend before once in a while before I ever did anything to my car. it does it when i'm coming to an abrupt stop and step on the clutch and throw it in neutral
Old Sep 6, 2008 | 11:42 PM
snowboi1289's Avatar
I've seen this problem before at my auto class. We were going to do an engine swap on a Toyota Carrola (I hope I spelled that right), we decided not to. The engine in it now had a problem almost like your problem, except its an automatic. We took the TB off, and cleaned it with brake cleaner. The butterfly in the TB was just covered in that bad stuff, you know what I'm talkin' about.
After we cleaned it all up, we noticed a fair amount of change in the idle control. We almost got into a wreck, well sorta. It was parked with the E-brake on, and suddenly, it slamed into drive(somebody must have slipped it into netral). We fixed it by removing the TP(throttle position) screw.
What I'm trying to get at, is it must be a problem with either the throttle body, throttle position sensor, and/or the the intake(somehow).
Sorry for the long story, I was trying to make a point. Also, sorry if this doesnt help you.
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
