cruise control not working
Old Sep 14, 2008 | 06:52 PM
arrocha87's Avatar
1995 SE 5pd. ok so i use my cruise control almost everyday. today on my way to walmart it just wouldnt turn on. i checked all the fuses and they are all good and my cruise control light on the dash and button light up. it just wont engage? any help would be appreciated.....
Old Sep 14, 2008 | 07:31 PM
99se5speed's Avatar
SHIFT_up
don't mean to hijack but i'm having the same issue but it won't engage and the light doesn't turn on...tried diff module to no avail...
Old Sep 14, 2008 | 10:33 PM
arrocha87's Avatar
any1?
Old Sep 15, 2008 | 07:36 AM
oldngivout's Avatar
Willing to learn
Check the operation of the cancel switch on the clutch pedal. Actually, there are two switches, one for ASCD cancel & one for safety start. The ASCD switch will be a normally closed version, meaning that it should only be open when released, as when depressing the pedal.
Old Sep 15, 2008 | 10:13 AM
jlithen's Avatar
I just fixed my cruise on my 1995 Max for maybe two months ago but it was a VDO tempostat from 1994. It was sometimes working and mostly not, sometimes it would also shut of when driving. It was very annoying since I was mostly driving longer distances then. Anyway I called a place that repaired car gauges and cruise controllers (surprised there is such a company) and they said that they can with a 50 % probability fix it. A new one would have cost 600€ and they said it is usually just a cold solder joint.
They seemed to know what they wer talking about and they said it is very common in Nissan (gauges) and very common in VDO (cruise) so I removed the controll PCB from its aluminum box (was under the radio for me) and stripped of the old varnish with acetoen and a toothbrush. Had to apply many times but all came loose. Then I heated every joint and added some solder too. The cruise worked immediately perfectly!
I'm not sure if this helps you at all but I thought I would say it anyway
Old Sep 15, 2008 | 12:21 PM
arrocha87's Avatar
ill go check the fsm to find out exactly what i need, but what would i be looking for?
Old Sep 15, 2008 | 12:22 PM
arrocha87's Avatar
so the alarm box or whatever its called controls the cruise control too? wow i need to read a my fsm a lil better.
Old Sep 15, 2008 | 01:12 PM
oldngivout's Avatar
Willing to learn
Just disconnect the switch, then use the ohmmeter to probe the terminals in the switch.
Normally closed should read zero ohms, then go to infinity when depressed.
Old Sep 15, 2008 | 01:13 PM
arrocha87's Avatar
oh ok. ill go dig trough my moms garage and see if i can find my ohm meter.
Old Jun 27, 2009 | 09:31 PM
v_c@yahoo.com's Avatar
Anyone happen to know the part number for [switch assy - ascd cancel]
Old Jun 27, 2009 | 09:48 PM
pmohr's Avatar
No more Maximas...
Assuming you're referring to the one on the brake/clutch pedal?
Rather than the Nissan name, an actual description would be helpful.
Assuming you do mean that one, then
25300-62J0E, $26.14 each at Courtesy
FWIW there's no real reason to dig up a 9 month old thread just for a part number, could've posted in the newbie thread.
Old Jun 27, 2009 | 10:37 PM
Thanks for the info. I did a search and thought someone in this thread would know....and you did! Thanks Again.
Old Jun 27, 2009 | 10:46 PM
iluvbeatles's Avatar
Maybe there's a prob with the connection...
Old Jun 27, 2009 | 10:56 PM
Mu_036sp's Avatar
Did you Recently change any Light bulbs? i know in the 00-01 5th gens if you convert the Tails to LED bulbs. Cruise control doesnt work. Weird. but not all do it. its some. so if you did any mods. Try to undo it and see if cruise comes back.
Old Jun 27, 2009 | 11:26 PM
I tested the switch with an ohm meter and it failed the continuity test. I should replace it before I move on to the rest of the diagnostic tests.
Old May 17, 2014 | 01:06 PM
Steve0835's Avatar
I had a similar problem on my 1995 Maxima SE. The light on the switch to turn on the cruise control would light up, but the light on the dashboard never came on. I took out the ASCD Clutch Relay and shorted the terminals 6 and 7 (like if the relay is activated) and the cruise control WORKED. The problem was the ASCD CANCEL SWITCH, activated by the clutch pedal. Replacing this switch is easy.
This makes sense. This switch opens as soon as one presses the clutch pedal (to disconnect the cruise control and prevent the engine from revving when it does not push the car anymore and the cruise control would try to drive it harder). The switch is activated every time we switch gears, so it gets constant use, much more than the switch on the break pedal. So after nearly 20 years of use, mine gave up!
I got the new switch from partsgeek.com for $22.41
Old May 17, 2014 | 03:51 PM
asand1's Avatar
5 year necro bump.
More often than not its just the rubber bumper that fell out of the pedal.
MikesChevelle
Nov 23, 2024 11:17 AM
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
MikesChevelle
Aug 6, 2015 11:36 AM
