radatior problem?
Old Sep 16, 2008 | 01:35 PM
blacmagic's Avatar
radatior problem?
yo lately I've been using alot of anti-freeze and i smell an odor that smells like coolant. I think i may need a new radiator and if i do should i get OEM or aftermarket?
Old Sep 16, 2008 | 02:00 PM
alset2's Avatar
I would find the leak first.
what makes you think its the radiator?
Old Sep 16, 2008 | 02:30 PM
maf2003111's Avatar
see where the leak is 1st. it could be rad/hoses/water pump seal
Old Sep 16, 2008 | 03:18 PM
vilmaxima's Avatar
find the leak, you might get lucky and just need to tighten something or replace a hose.
Old Sep 16, 2008 | 05:32 PM
blacmagic's Avatar
it looks like its coming from the top of the radiator. All the anti-freeze is all over the engine bay
Old Sep 16, 2008 | 06:01 PM
Sounds like the top piece that is plastic cracked. Double check that, otherwise it still could be a loose clamp or cracked hose issue.
Old Sep 20, 2008 | 04:01 PM
97_Max's Avatar
Same problem with mine, I found the crack its on the top of te radtior where it has that square I believe it says NISSAN or something like that. What could be done?
Old Sep 20, 2008 | 09:21 PM
CMax03's Avatar
It's best to just get a new one or (alternative) have the radiator shop replace the top tank assy and gasket!
Old Sep 20, 2008 | 10:14 PM
Snypa's Avatar
Junkyard.
Old Sep 20, 2008 | 10:49 PM
G4nismo's Avatar
if need replaced, just get a koyo rad replacement.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
