Bars....? What the heck are they?
Old Nov 4, 2000 | 04:36 PM
Nick Robinson's Avatar
I see on websites that sell stuff to mod out your Max, bars. Like a strut tower bar or a Stillen Rear Sway Bar. What the heck are they? ANd why do you want one?
Thanks =)
Old Nov 4, 2000 | 04:57 PM
Micah95GLE's Avatar
https://maxima.org/maxfaqs/sub_suspe...#Suspension_1a
Old Nov 4, 2000 | 08:25 PM
VQ Quick's Avatar
DUDE! you must have these.
They are performance upgrades that tighten and stiffen thee flexing chassis. - Thus you get improved handling.
FSTB - $50. 5 minutes to put on yourself.
Rear Sway Bar - $240 ish - 15 minutes tops to put on.
These will transform you car into a much better handling machine - GUARNATEED. Nissan puts em on some of their Infinit's and the late 300Z had em too. But I gues they save money by not including these as standard equipment.
Old Nov 5, 2000 | 04:37 AM
chris j vurnis's Avatar
Hello:
Well, here is how they work:
Strut tower bars... Basically they bolt between the tops of the strut towers and go acrose the engine and trunk. By bolting a big stiff piece of alumimum in the frame work of the car, the frame gets stiffer... which is a very good thing... Think of the strut towers and the contact patch of the tires like a big arc angle... Just a slight flex of the strut towers (i.e. tiny fractions of a degree) can translate into much bigger distances when that same angle is extended out about 3 feet to the ground... so the more the frame is tightened, the more stable the alignment angles are through a turn...
Stabilizer bars...
As a car rolls in a turn, weight is transferred to the outside end of the car... For example, take a left turn and the weight moves to the right... assuming the ride height stays the same, you could have a soft suspension or a bone-crushingly stiff suspension and the same amount of weight will transfer in a turn assuming that speed and radius are the same...
Anyway, a stabilizer bar is rather rigid... So as weight is transfered to the outside of the turn, those wieght transfer forces travel back along the bar towards the inside end of the suspension and for the most part give a downward force on that end of the car... But also, big stiff bars don't bend or stretch easily... If one end of the suspension wants to go up and the other end wants to go down, those tendencies are greatly limited by bolting the bar between the two ends...so you get a lot less body roll
Old Nov 5, 2000 | 07:45 AM
VQ Quick's Avatar
What he said.
Explained in plain English too.
Old Nov 6, 2000 | 07:48 AM
SmoothMax's Avatar
OG
Re: What he said.
Yeah, what they said.
Old Nov 6, 2000 | 08:23 AM
breaux124's Avatar
Re: DUDE! you must have these.
The addco RSB is as cheap as $120. The Stillen RSB is the expensive one, because it's adjustable and it's stillen.
The Wizard
24
Oct 1, 2015 08:47 PM
sliptap
Sep 30, 2015 05:57 AM
05RLS2
Sep 27, 2015 09:24 PM
kling's maxima
Sep 3, 2015 04:45 AM
Stelianos
Aug 19, 2015 02:07 PM
