a/c compressor replacement question
Old Sep 22, 2008 | 11:39 PM
DcMaN's Avatar
I need to replace my ac compressor. I actually just need to replace the pulley but i can't get it off so im gonna change out the whole compressor. Does anyone know if they are all universal 97~01 ? I have a 97 nissan maxima. I think the 95-96 compressors are different and 97 to 01 are all unviersal. Any help would be greatly appreciated.
Old Sep 23, 2008 | 05:25 AM
njmaxseltd's Avatar
They are not all the same. Later 4th gens don't cycle, the system pressure is regulated internally. You need the correct compressor for your application.
Old Sep 23, 2008 | 06:27 AM
Turbobink's Avatar
why in God's name would you replace an entire compressor for the sake of a bad pulley?
if i'm not mistaken a new pulley assembly is like $80 whereas a compressor is anywhere from $300 to $500.
a compressor clutch holding tool is like $19. a pulley puller is about $23. and snap ring tool kit is around $19. all of these tools can be loaned from an auto parts store.
a new pulley bearing (if that's what's gone bad) is about $30 to $35 and a machine shop will charge you maybe $20 to press out the old and press in the new.
pull the pulley and replace it.
Old Sep 23, 2008 | 09:13 AM
kelster23's Avatar
Plus, if you're going to pull the compressor, you're gonna have to take the car somewhere to have the refrigerant discharged , then recharged after the swap...not cheap.
Old Sep 23, 2008 | 09:19 AM
DcMaN's Avatar
The pulley won't come off, i waited so long that the bearing was riding on the shaft and mustve gotten worn so bad it will not come off now.
Old Sep 23, 2008 | 10:58 AM
Turbobink's Avatar
how are you trying to remove the pulley?
bare hands, vice grips, a pickle fork, c-clamps and a hammer ain't gonna work.
even with the right tools, if you can't get it off, go and have the system evacuated, remove the compressor and take the whole thing to a machine shop. they'll be able to remove the pulley... there again you'll have saved anywhere from $250 to $450.
but hey, if you just like buying and installing new parts for sake of buying and installing new parts, have at it.
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
dr3am
25
Oct 22, 2015 08:53 PM
scarletsosa
Aug 17, 2015 09:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
