brake hardware kit - extra
Old Sep 25, 2008 | 05:30 PM
joew's Avatar
does anyone know what the extra shiny metal below the shims in the pictures are for? thanks.
Old Sep 25, 2008 | 06:17 PM
nitromax's Avatar
hardware kits will usually fit more than one car, but with some different pieces. use the ones for your application & toss the extras. since this kit is oe double check with the dealer for the other apps to see if the extras are worth saving...(in case they fit "my other car is a...").
Old Sep 25, 2008 | 06:24 PM
RA030726's Avatar
I'm nutty for Nissans
id say they go between the piston and the black shim
Old Sep 25, 2008 | 06:40 PM
nsnrider's Avatar
double shim...
Nopike's Avatar
You would be right.
http://www.courtesyparts.com/betasit...1879_1880.html
Old Sep 25, 2008 | 07:59 PM
joew's Avatar
thanks folks, do you use anti-squeal glue and then attach it to the shim?
Old Sep 25, 2008 | 08:18 PM
Nopike's Avatar
I don't know for sure but when I installed my shims I did not use any anti-squeal at all and they worked just fine. I don't think that you need it.
Old Sep 25, 2008 | 08:28 PM
joew's Avatar
i am sorry i mean if you apply anti-squeal on outer shiny shim and then attach it to the black shim? i guess i maybe the first person to receive this extra piece of hardware or maybe i have received the wrong hardware. the shims seem to fit the pads. i just want to confirm before i get started.
Old Sep 25, 2008 | 11:25 PM
maximase86's Avatar
I love lamp.
I would put anti squeel on the back of the pad, and on the back of the shim.
S
Old Sep 25, 2008 | 11:35 PM
hot_wax_tree's Avatar
Originally Posted by Nopike
there she is!!
Old Sep 26, 2008 | 09:44 AM
dgeesaman's Avatar
Maintenance Monster
No goo between the shims. Check your FSM.
The friction between the layers is what makes them work.
Dave
Old Sep 26, 2008 | 07:01 PM
joew's Avatar
thanks folks, i found out that the shiny plate metal is called shim cover.
last question, what size c-clamp do you use for the front brakes. 4" or 6"?
Old Sep 26, 2008 | 07:08 PM
Nopike's Avatar
Either one will probably work, I'd go with the 6" just to make sure does not end up being too small.
Old Sep 26, 2008 | 08:10 PM
joew's Avatar
thanks for all the help. it will be a complete brake job on the front and the rear. i know about the tool for the rear brake. thanks all.
Old Oct 5, 2008 | 09:04 AM
Chitownson's Avatar
I would definitely put anti-squeal between the shims and the brake pads. I always buy Raybestos pads (I uses ceramic in fronts and semi-metalics in back, last 2-3 years) but some of the cheaper crap pads out there (autozone, Pepboys - typically made in china garbage) have such poor quality fitting on shims they rattle once installed. I also don't use the anti squeal these clowns sell. The stuff doesn't have a good hi-temp resistance and once turned to dust on my Maxima. My friend recommended Red RTV (find it in the gasket section) and the stuff works great.
Old Oct 5, 2008 | 06:18 PM
joew's Avatar
i just finished working on the front brakes today. on one side, i forgot to untwist the cap on the brake fluid reservoir while i was pushing the piston back. am i in trouble?
Chitownson, how much longer does the Red RTV last compare to the regular anti-squeal glue?
Old Apr 11, 2009 | 02:59 PM
Chitownson's Avatar
I've been going 2 years on a brake job and I drive pretty agressively.....
Old Apr 11, 2009 | 03:09 PM
pmohr's Avatar
No more Maximas...
6 months later...
Miket2006
Mar 1, 2021 03:55 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
