How To: Get Rid of ANY Brake Dust
Hey, guys I decided to post this once I finally had it with all the baked on brake dust that was impossible to remove with any cleaner...and I tired Everything you can name...Nothing would remove this...Until Today...
WEAR SAFTEY GLASSES, AND CHEMICAL RESISTANT GLOVES!! This is a MUST!!
Before...
![](http://i422.photobucket.com/albums/pp307/btvenom/th_HPIM1581.jpg)
After...
BE CAREFUL This stuff means business, just look at how clean it got my caliper just from sitting on there for 30-45 seconds!!
Ignore the rusted rotor, that's from water, it will come off with first use of brakes. My wheels, are even more shiny, because the above finished photo was taken before I polished them![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
The Process
The Required Things
I used Meguiars Wheel Brightener, Item # D14001
![](http://www.meguiarsdirect.com/imagesEdp/p84760b.jpg)
Dilute it 4:1 as directed in Wheel Brightener Bottle Item # D20140 or a 32 ounce bottle
I would not dilute this solution, any more than this as it would be too strong, and trust me, If you have looked at the photos this was done with Very Light agitation with #0000 Steel Wool, it's smooth enough that it wont scratch your wheels, if you press lightly.
Before...
After...
![](http://i422.photobucket.com/albums/pp307/btvenom/th_HPIM1583.jpg)
The Process
- Rinse Wheels to remove loose dirt with hose
- Spray 4:1 Diluted Wheel Brightener onto wheels
- Let soak for 30-45 Seconds NO MORE
- Then begin to lightly scrub with #0000 Extra Fine Steel Wool
- After desired cleanliness is obtained thoroughly rinse with water
- Optional: Wash wheels with soap and water to ensure all brightener was removed
- Use a polish such as Mothers Mag & Aluminum Polish, something safe for Alloy Wheels, to put a protective and shiny coating on your now clean wheels
The Required Things
Looks like it works good, we use a product called NU-WALL at work(car wash ha). That stuff we have is very potent. We dilute 5 parts water 1 part nu-wall. Our stuff will make the inside of the wheel look like new without scrubbing, of course I spray it off with a pressure washer but yea good product.
i just washed my car today and was thinking about what i was going to do about all the baked on brake dust that wouldn't come off. I had no idea what i was going to to but i guess this answers my problem. Thanks!
I used something like this at work, and it said right on the package only to use on OEM wheels.
Personally, I wouldn't ever use anything this abrasive on my wheels, as it eats away the clear coat...especially on aftermarket wheels.
^^^ yep, your wheels have gotta be pretty frickin dirty to use this stuff. my wheels never need more than a quick wipe down cause im **** about keepin them clean. when i see another max with baked on brake dust i think " man, i would never consider buying that car" cause its dirty so i figure they dont keep it maintained mechanically either. you know what they say, " first impressions and all......
I wouldnt spray it on your cars paint, but just make sure if you see overspray onto your car that you spray it off really well.
No problem glad I could help!
It depends what the wheel is made out of, it's not safe to use on uncoated alluminum wheels.
But used in the Correct dilution ratio, it's safe to use on anything! Except uncoated alluminum...
Haha, you really dont have to scrub... I just used steel wool becuase it felt better than using my finger turning numb, plus it has more surface area, and is harmless to the wheels, unless you GRIND it into it... but after you use this stuff you can rub brake dust off with your finger's, it's pretty harmless stuff as long as you use it in the correct dilution ratio
I bought my car with rims that had crazy amounts of brake dust. Its been a losing struggle trying to keep them clean because its impossible to get it out of the crevices. And the clear coat is basically junk from all the scrubbing ive done on them.
What I need to do is soak my rims in this stuff, then use that aircraft paint stripper, and then repaint and start brand new.
This is serious stuff, My wheels were in horrible condition, I tried every cleaner at Advance Auto Parts, and none of them worked a single bit, every single method I tried before this stuff didn't work. Until I tried this wheel brightener, so be careful this is serious ****...Please take the appropriate safety precautions!
Well I currently have Hawk HPS Performance Brake pads, which dont give me any dust problems, all that dust was from he old brake pads, and I couldnt get it off...until I found this wheel brightenener stuff.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
