General LED Mods
Old Jan 29, 2009 | 06:24 PM
  #41
klemenz's Avatar
I just spliced into cigarette lighter for the power source they would only come on with the car started. Then I drilled a hole in one of those blank switch plastic things and put a toggle switch in it.
There's plenty of space under the dash to run wires just get a flashlight and look around.
If you want to put them under the front seats to illuminate the rear floor then all you have to do is get a screwdriver and carefully pry the trim off the center console area and run the wires there.
OR you could pry up the trim at the bottom of the door sill and run the wires through that (but it requires a little more effort imo)
It's really easy and you can probably diy with little problems. Just using your imagination and correct tools will make it a breeze
Old Jan 30, 2009 | 07:50 PM
  #42
thomatt12's Avatar
^^ Thank you very much for the tips on how to properly install those LEDs in the interior. I think I just might give it a try.
__________________
ram air intake
Old Jan 30, 2009 | 08:33 PM
  #43
klemenz's Avatar
If you need some help I can take some pictures just pm me
Old Jan 31, 2009 | 12:11 AM
  #44
bksmax11203's Avatar
good write up
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
