Exhaust Too Loud (silencers???)
Old Oct 12, 2008 | 07:12 PM
jxkim's Avatar
i recently failed my inspection because my exhaust is "too loud". i have a budget ypipe + greddy sp2 catback. http://www.youtube.com/watch?v=0yljpHmPvbE
i know the sp2 itself would pass, but with the aftermarket ypipe all that airflow causes the sp2 to be pretty damn loud. are there any solutions? perhaps buying a "silencer"? honestly i have no clue if they work and which one i would need to get...
i know removing the ypipe would help me pass but i rather not go that route.
please help
thanks
Old Oct 12, 2008 | 07:45 PM
tigersharkdude's Avatar
I dont know if you still have a resonator, if you do change it to something thatll quiet it down a bit
Old Oct 12, 2008 | 07:47 PM
black_maxed95's Avatar
are you positive you have no exhaust leaks? I have the same setup and its not loud at all, especially for normal driving.
Old Oct 13, 2008 | 10:25 AM
Get the biggest resonator you can fit.
Old Oct 13, 2008 | 10:34 AM
MrDicks95SE's Avatar
Offset Is Everything.
or two medium-sized resonators. cheaper with the larger resonator tho.
Old Oct 13, 2008 | 10:47 AM
jd885's Avatar
I had a Y-Pipe and stillen catback... never failed best thing to do that my buddy did with his Max is buy a cheap *** muffler... unbolt the SP2 muffler and slap a stocker on there for inspection... and keep the stock for when you need to do inspection.... OR FIND A INSPECTION STATION THAT ISNT SO STRICT... some of them are crazy
Old Oct 13, 2008 | 11:04 AM
dralucard's Avatar
where did you go, lodi? i have a ws y and an sp1 and have to go in december.
Old Oct 13, 2008 | 01:18 PM
19max95's Avatar
yep, thats exactly how mine sounded with the Warp Y and sp1 catback... i removed the y and its a night and day in preformance and sound....
Old Oct 14, 2008 | 05:38 AM
jxkim's Avatar
yea i went to lodi, nj
but the dmv inspections are same where ever you go
i do have a resonator in the bpipe of the sp2.
does this mean there is no quick fix? i.e. silencers
Old Oct 14, 2008 | 06:39 AM
dralucard's Avatar
you might have to go to a local garage and pay $.
Old Oct 14, 2008 | 10:04 AM
The quickest 'fix' is to put your OEM ypipe back on.... I know that's not what you want to hear.
Old Oct 14, 2008 | 11:00 AM
bohead's Avatar
I have a y-pipe, hiflo cat, NO resonator and a custom Apex'i Dunk catbacks system. Lets just say my setup is pretty damn loud. So in order to avoid the popo and unwanted tickets I installed this:
http://www.apexi-usa.com/product_exh...=251&pageNum=1
Its not a direct fit for us maximas but with a couple minor mods, it works like a charm!
It allows me to activate the silencer from inside the cabin without having to pullover to install the silencer. There have been many occasions when I've been cruising along and out of nowhere, a popo peers its ugly head. I quickly pull up the valve and instant silence. Granted you don't want to be driving around for too long with this enabled. Its more of a quick fix to get you out of trouble!
But for emissions testing...best bet is to swap in OEM then swap out after the test.
Old Oct 14, 2008 | 06:22 PM
thomatt12's Avatar
I used to have the same problem. My solution, I replaced my freeflow muffler with chambered type ones. They are more quiet and smoother if you'd ask me.
__________________
CRE
Old Oct 14, 2008 | 08:22 PM
Chirp2nd's Avatar
hey everybody with the greddy sp2. do u guys have a problem with the b pipe hanging lower then it should be near the side of the car? because my b pipe hangs really low. if ur 6 feet away from my car u can see it.
Old Oct 15, 2008 | 09:55 AM
sonicrunch's Avatar
A glasspack muffler works very well as a resonator. It's also cheaper than a resonator.
Old Oct 15, 2008 | 07:59 PM
jxkim's Avatar
yes. this is common problem for the max. either you live with it (like me) or theres some fixes that might work. i recall someone telling me before you tighten the bolts you place some blocks or anything to hold the bpipe in position. jack your car up and then slowly lower onto the block. once its in a good position, tighten the bolts. beware i have not done this, but i would imagine you would not want to rush this process. problem is because most catbacks installed are with the car raised way high and no real force holding the bpipe in correct position (poor fit for max to be honest with you)
Old Oct 15, 2008 | 08:01 PM
jxkim's Avatar
mmm i would if i still had it. having a 13 yr old car in the ny/nj area, my exhaust parts were all rusted badly. i couldnt even sell it. just tossed it. yea i rather pay a garage $75 to do my inspection, given i passed emissions and all. failed for something silly
Old Oct 15, 2008 | 08:02 PM
Chirp2nd's Avatar
thanks jxkim. maybe ill try sumthin of the sort to fix it.
Old Oct 16, 2008 | 07:58 PM
dkillahster's Avatar
here is a quick silencer
Shove the largest bananna or sock in the exhaust pipe away from view... that will quiet it down a bit. my .02 cents. xD
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Socalstillen
Sep 26, 2015 12:01 PM
