Clutch interlock override?
Old Oct 15, 2008 | 08:36 PM
GStrength's Avatar
I want to override the clutch interlock switch so the clutch pedal doesn't need to be fully pressed in order to crank the car. I was planning on snipping the wires from the harness and twisting them together and taping it up.
Old Oct 15, 2008 | 08:42 PM
jasonaaronfox's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOO
first of all I think there is a fuse you can pull out under you hood to do that; secondly, just disconnect the electronics from next to your clutch and stick a paperclip from one prong to another. -- I have this done on my max.
My Lord man!?!?!? What were you thinking! ^___^
Old Oct 15, 2008 | 09:13 PM
f550maranello2's Avatar
run the wires to the hand brake...
OR ur gonna have to use a couple of relays to make the car not start when in gear..
Old Oct 15, 2008 | 09:47 PM
Or try paying attention?
Old Oct 15, 2008 | 10:11 PM
hey noob.. eat my a$$ with your ghetto paper clip rigging.. if ur gonna do something do it once and do it right by disabling the starter when the car is in gear...
Old Oct 15, 2008 | 10:13 PM
actually, a shop did it as a favor while fixing another issue in my car. The clutch was installed crappy by the last person that owned the car(crying shame to install a Kevlar clutch and do a bad job ) making it nearly impossible to start the car. Ghetto yes, but free!
And I'm too broke to get the clutch wired up correctly! ^___^
Old Oct 15, 2008 | 11:23 PM
pmohr's Avatar
No more Maximas...
For my 5 speed swap, I wired the neutral switch on the trans to the stock auto park/neutral setup, so the car only starts in neutral. No worries about my remote starter or having any sort of 'accident'. You could do the same by wiring the clutch switch to the neutral position switch at the ECU.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
