ever lift the car to fix axle problems??
Old Oct 16, 2008 | 05:23 AM
j2b4osan's Avatar
ok so I know allot of you think that a drop lower than 1.5" ruins axles.
so my question is has anyone with a problem killing axles(pass side) lifted the car (back to stock or close)in order to stop it re occurring and if so did it work?
also has anyone with a clicking axle lifted the car and noticed the click gone away without replacing the axle??
Old Oct 16, 2008 | 06:27 AM
internetautomar's Avatar
mod or sell?
once it starts clicking the axle needs to be replaced.
Old Oct 16, 2008 | 09:11 AM
Snypa's Avatar
Old Oct 16, 2008 | 11:02 AM
j2b4osan's Avatar
So am I to believe that everyone on this forum that has more than a 1.5" drop just replaces axles every 4-6 months. I find this hard to believe
Old Oct 16, 2008 | 11:12 AM
QNO_A32's Avatar
ummm no....... yeah i usually replace my axles every oil change. you have a lot of reading to do...and +2 for what they said.
Old Oct 16, 2008 | 11:23 AM
j2b4osan's Avatar
I've read all the bs arguments and am still looking for one single person to say that they were blowin axles because of the drop but when they raised it they stopped breaking. That's what I'm looking for someone who has EXPERIENCE with a drop below 1.5".
I really don't feel like shellin out money for a new axle if it's just going to blow again. If someone has had sucess with a milder drop than I will just get htecs and than replace the axle. Thanks for condesending newbie it helps alot.
Old Oct 16, 2008 | 11:35 AM
QNO_A32's Avatar
yeah you know the drop kills them.what you got now coilovers or springs? replace the axle and use h techs and the axles will last a long time. i do have a drop below 1.5 inches and my axles have been good for a while.
Old Oct 16, 2008 | 11:40 AM
Crusher103's Avatar
im lowered by 1.7 i dont have alot of axle problems. they just get old and u have to replace them thats normal maintenance.
Old Oct 16, 2008 | 11:48 AM
j2b4osan's Avatar
It's a raxle and it's less than 6 months old. And I'm on stec's now
Mabye I need a camber kit??
Old Oct 16, 2008 | 02:41 PM
RA030726's Avatar
I'm nutty for Nissans
I have been at several heights, from stock to dropped nearly 3" . Not one issue. I have the stock 98 pass axle (120k) and an 01 AE LSD driver axle (80k?). Granted I dont drive as much as most and dont slam the car very long either. I am also currently on Stechs. I do not like these springs, so its temporary, but I do believe they are too low. FYI, Stechs rest on the bump stops with a stock strut. You really cant go any lower with out modifying something. I also swap in the stock suspension during the winter, Nov.-Apr. That must give the axles a break.
My cousin on the other hand has gone through countless axles, wheel bearings, and tires. He as a very aggressive driver. He drives many many more miles than I. He also leaves the springs on all year. He was on cut Intrax which are as low as Stechs for sure. He bought new, not reman, axles at advanced auto, which have a lifetime warranty. Free fix in part, it just takes a few hours of time. He switched to Progress and I dont think he has replaced an axle since.
It all boils down to how hard the axles are being worked. The CV joints can only rotate properly till a certain angle. Obviously running them at less of an angle will last longer.
Old Oct 16, 2008 | 02:50 PM
j2b4osan's Avatar
so in your opinion would a camber kit help?? or nothing but stretching the control arms or going higher would help.
also my bump stops are trimmed to almost non existence. it was like that when I got the car.
I do live in NY and drive it atleast 35 miles a day.
anyone know how much nissan wants for a new one?
Old Oct 16, 2008 | 06:45 PM
choray911's Avatar
The Crazy Azz Cracka
I have been as low as 2.5 inches for 9 years while turbo'd and N/A, and have not had to replace them. Are you making sure the axle nut is tight? That can lead to unwanted subharmonic vibration that can lead to axle and bearing failure.
Old Oct 16, 2008 | 06:59 PM
j2b4osan's Avatar
Im going to double check tomoro when I take it off and put a new one on.but Im pretty sure I double checked when I put it on.
I think Im going to try and get an advance auto new lifetime one. its 60$ and I gotta go on a 5hr trip monday so i almost dont have a choice (my yota is way to small for me on long trips).
could old suspension bushings kill the axles that fast? they arent cracked or anything but Im sure they are old.
Old Oct 16, 2008 | 07:17 PM
RA030726's Avatar
I dont think a camber kit will do anything.
Old Oct 16, 2008 | 07:38 PM
QNO_A32's Avatar
i just cant see s-techs blowing a raxle in 6 months...
Old Oct 17, 2008 | 04:43 AM
j2b4osan's Avatar
So you want to see mine? (LOL)
so what could you see killing that raxle prematurely
And it's less than6 months old and it deteriorated far faster than the last cheap one.
And on a side note the driver side was replaced at the same time with a napa cheap reman(30$) and it's still good.
Old Oct 17, 2008 | 04:49 AM
AEMAXIMA01's Avatar
Every oil change? That seems like a lot of work....
Old Oct 17, 2008 | 04:55 AM
j2b4osan's Avatar
I saw someone say that bad trannie berings will kill and axle.
So how would I diagnose if this were the problem. (changed to amsoil gl4 gear oil)
Is there a sound associated like bad wheel berings in the tranny or something?
Old Oct 18, 2008 | 01:09 AM
EZEMaxima's Avatar
Got 60K on my Max and has change my passenger side 3 times and recently replaced the driver's side. I'm riding on JIC coilovers on 19" wheels and I like to push my ride especially coming out of the corners. I've been told that these crazy driving habit of mine is causing the failure of my axles...
Old Oct 18, 2008 | 05:38 AM
j2b4osan's Avatar
ok so last week or the week before that I got new rear tires, and I had the wheels ballanced and rotated. Few days after that the axle started to sound really bad. Yesterday I actually put the car up to check everything out, and when I went to remove the pass side front wheel my impact didnt even make a single click on 3 out of 5 lugs. Only one lug was fully tight. Thank god I wasn't killed by some douche at firestone that would have been lame. So obviously this was the prob. I'm kickin myself for not checkin sooner. I just figured guys doing tires all day would know how to mount a wheel. There were loose lugs on all the wheels, the worst being in the front. Wtf WTF WTF.
Now that everything is tight everything is happy, I only get very mild click at full turn now.
This makes me want to get a tire mounter for my garage.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
erniel
Aug 8, 2015 09:32 AM
acw
Aug 7, 2015 04:20 PM
