Slave/Master Cylinder Issue
Old Oct 22, 2008 | 01:55 PM
KDog125's Avatar
so the other morning I try to move my car and the clutch pedal kept ketting stuck as I let go and was unable to put car in gear when car was started only wen it was off I was able to put in gear...So i was able to start car in first and took to mechanic....
He says the slave cylinder needs to be replaced as well as the brake master cylinder...do they correspond at all to the clutch pedal being stuck? He said the brake master cylinder needs to replaced something to do with hydrolic system or something...any comments? thanks a lot
Old Oct 22, 2008 | 02:11 PM
alset2's Avatar
Are you sure he didnt mean the "clutch" master cyl.?
the brake master has nothing to do with your clutch.
Old Oct 22, 2008 | 03:45 PM
pmohr's Avatar
No more Maximas...
Have you tried bleeding it first? I imagine your clutch fluid reservoir is dry?
Also, look around for leaks. More than likely it's around the lower clutch line.
Old Oct 23, 2008 | 01:02 AM
NY2NJMAX's Avatar
same thing happen to mine, kept sticking , changed the slave and clutch master cylinder. works perfect now
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
bbsitum
Sep 11, 2015 04:55 PM
