03 hid kit in 97
Old Oct 23, 2008 | 09:22 AM
95stillenmax's Avatar
03 hid kit in 97
how do i use a 5.5 gen hid kit in my 4th gen?
Old Oct 23, 2008 | 10:20 AM
Torgus's Avatar
you don't?
Old Oct 23, 2008 | 11:15 AM
darklegend06's Avatar
why would you do that?
retro some projectors if you want HID
Old Oct 23, 2008 | 11:18 AM
kzoosho's Avatar
He can use everything bout the housings i.e the ballast and bulbs. You would still need projectors tho.
Old Oct 23, 2008 | 01:37 PM
nalc's Avatar
the bulbs wouldn't be the best though... the 5.5 has D2R, which has an integrated shield. most projectors are designed for D2S, and have the cutoff shield as part of the projector housing (between the bowl and the lens)
Old Oct 23, 2008 | 03:08 PM
Kevlo911's Avatar
Kevlo for President
You cant. You could only use the ballast and even then you would be better off doing a projector retrofit or getting an hid kit. Check www.hidplanet.com for lots of lighting info or search here.
Old Oct 24, 2008 | 05:00 PM
JtzMax's Avatar
Whatchyou say?
I agree .... you'd be much better off to either do a retro yourself, or have someone do it for you. You get many more options as far as output / cutoff / quality. There are so many projectors that will fit, why whould you even consider trying to use OEM 5.5 set up? The housings are different, if you look, you'll see.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
