Grinding Noise from Rear Brakes
Old Oct 25, 2008 | 01:18 PM
LILMAN's Avatar
While comming to a stop I get a griding noise from the rear brakes. I narrowed the noise down to the paseenger side wheel. After inspection of the pads I did not notice any wear on the pads or rotor. I'm thinking the caliper is sticking closed. Can I just replace the seals in the caliper and call it a day or should I try bleeding the line first?
Old Oct 25, 2008 | 01:26 PM
QNO_A32's Avatar
these cars are known for the rear calipers not being the best. i would check the rear brakes again, check the inboard pads and the back of the rotor. might need CPR on the back.
Old Oct 25, 2008 | 01:30 PM
LILMAN's Avatar
I got some rear pads around. Should I try to swap them and see what happens?
Swapped out the pads. Not as much noise but it's still there a lil.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
carlosvq30
Aug 17, 2015 11:32 AM
egali045
Aug 16, 2015 01:19 PM
