Semi-urgent: o2 sensor bung thread size?
Old Oct 28, 2008 | 12:39 PM
foxracing12's Avatar
Was about to get my inspection finally, riding on an almost expired R. CEL comes back on for a different problem than original, system too lean and bank 1 o2 sensor no voltage. The threads on the aftermarket y pipe were always sketchy and I always had the o2 sensor about 75% threaded in (stupid, i know). It worked but now I want to fix the threads before changing the sensor. Does anyone know the thread size on for the bank 1 o2 sensor on the y pipe? I think it's the same as bank 2. Thanks alot, its appreciated.
Old Oct 28, 2008 | 01:12 PM
Feldman's Avatar
so if i am understanding everything correctly you have an o2 sensor that is shot and the threads on your y are bad. If this is the case i would go and pick up a new sensor and then take it to sears or somewhere like that where you can buy or rent a tap and dye set and you can determine the correct thread size and pitch there instead of guessing.
Both bank 1 and 2 have the same thread size and pitch
Old Oct 28, 2008 | 02:48 PM
pmohr's Avatar
No more Maximas...
Those O2 sensor threads are 18x1.5.
Old Oct 28, 2008 | 03:43 PM
Thanks alot to both of you guys for the input, I will have to buy the tap asap and get this done..
Old Oct 29, 2008 | 12:11 AM
EZEMaxima's Avatar
Just rent it unless you think you'll be needing it again.
bbsitum
Sep 6, 2019 07:31 PM
conansriver
Sep 11, 2015 10:26 AM
