Replacing hood
Replacing hood
Hey so I finally got a CF hood...Sucks though because there are some scratches on it and the company I bought it from are jerks . Anyway... I'm gonna get it clear coated soon so do you recommend I just install it anyway and then get it coated? Also, I was just gonna remove this by guess and check, but is there a specific way to doing it? I notice the window washer squirter things are stuck in there too. Any way to get those bad boys out!? Help please
4 bolts, 2 nuts, and the windshield washer nozzle equipment is all you need to remove.
Does the CF hood have pre-drilled washer nozzle holes?
Yes it does come pre drilled for the nozzles and why would I wanna drive the hood down to the body shop? I dont even have a truck man. Why can't I just install it first and then get it clear coated haha? Do you know how to pop those nozzles out and yes I did search prior to posting.
Take another look at them, they should just pop out.
Ah I give up man. I keep scratchin the hood tryin to get that top bolt undone for the hood strut... The 11mm seems to small and the 12mm too big... Ughh I'm just gonna put in all the bolts and try another day I guess.
Hmmm... I should probably do a write up on this for future hood replacers haha. Anyway... that 11mm was too small for the hood supports and the 12mm too big... So I used a 7/8 and it fit perfectly! Now I'm stuck with the windshield wiper fluid nozzels and tubing. I got the tubing off of the nozzels, but I can't figure out how to pull the tubing out of the hood and the nozzels are stuck...ugh.
YourLocalAsian
08-17-2015 02:33 PM
