simply brakes question
Old Oct 30, 2008 | 06:44 PM
maxfever1987's Avatar
for those of you who change ur own front brakes, when changing the brakes and than pushing back the caliper piston do u OPEN the master cylinder cover or no? just wanted to know to be safe thanks in advance
Old Oct 30, 2008 | 06:55 PM
JNCoRacer's Avatar
Just the tip.
I have before. I didnt the other day though. No problems. No leaks.
Old Oct 30, 2008 | 07:12 PM
petro2342's Avatar
I never did.
Old Oct 30, 2008 | 07:14 PM
Feldman's Avatar
never have, i am sure you will be fine either way
Old Oct 30, 2008 | 07:25 PM
dgeesaman's Avatar
Maintenance Monster
You should not do it that way, you should open the bleeder at that brake and let the fluid push out there.
That said, I've also done it your way because I didn't know any better and nothing obviously bad happened. But the correct way is not hard so you might as well do it.
Old Oct 30, 2008 | 07:43 PM
Nopike's Avatar
Sounds like he does not intend to bleed the brakes, you generally do not have to bleed the system when just changing the pads. I've never opened the cover of the master cylinder when performing a brake job except to add fluid when bleeding. If you read the instructions for performing a brake job I don't believe the is ever a mention that the cover needs to be open. Although if you were to do it with the cover open it would not make any difference. I believe the master cylinder is vented so that the air displaced by the brake fluid will escape.
Old Oct 31, 2008 | 03:00 AM
dgeesaman's Avatar
Maintenance Monster
Like I said, *technically* you should open the bleeder and let fluid out at the brake when compressing the pistons, even if it's just to change pads. This isn't the same thing as bleeding the system, since you're only discarding the fluid that filled the caliper pistons.
But I usually don't do it that way.
Old Oct 31, 2008 | 05:35 AM
njmaxseltd's Avatar
Brake fluid is hydroscopic (absorbes moisture) and should be changed every time you do a brake job. That keeps the system clean and prevents corrosion which will cause your components to fail. It also helps to maintain a very firm brake pedal and fresh fluid has better temperature characteristics then older fluid.
It's cheap insurance for your brake system.
Old Oct 31, 2008 | 07:52 AM
internetautomar's Avatar
mod or sell?
I don't know about doing it every time, but every 2 years it should be done in northern climates (Chicago, newyouk, canada, etc..) where you have hot summers and cold winters. another indicator is if your fluid is dark, it should be clear to yellow in color.
Old Oct 31, 2008 | 09:43 AM
dgeesaman's Avatar
Maintenance Monster
I just do a full flush before every track day.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
