Water Pump... How's This One Look?
Old Nov 2, 2008 | 10:15 AM
Turbobink's Avatar
Any opinions?
I thought this aluminum one looked pretty good.
http://www.autozone.com/R,1755349/ve...ductDetail.htm
Old Nov 2, 2008 | 11:27 AM
oldngivout's Avatar
Willing to learn
First of all, if you are asking which tensioner to replace, you have a lot of research ahead of you on this subject.
And if you are asking about the AZ pump over the Nissan one, well, you should reconsider that. Get the factory pump.
Old Nov 2, 2008 | 11:49 AM
petro2342's Avatar
Oem ftw.
Old Nov 2, 2008 | 05:00 PM
Love_00_Max's Avatar
OEM pump($80) and OEM tensioner ($60) and get them from DaveB. If you are DIY such a hard job might elsewell get OEM components.
I chose OEM since I shelled out $450 for the replacement from my mechanic.
Old Nov 3, 2008 | 03:49 PM
Shift_my vq's Avatar
+1 oem
Old Nov 3, 2008 | 06:29 PM
Turbobink's Avatar
bought the Nissan part (water pump) from DaveB.
Old Nov 3, 2008 | 08:14 PM
B_Eaze's Avatar
rule of thumb, when changing anythin thats pretty easy (starters, belts, axles) autozone, napa, advanced are fine. anythin thats in a terrible or is an integral part of ur vehicle oem ftw... thats actual just my 2 cents not a rule of thumb
Old Nov 4, 2008 | 10:01 AM
ThurzNite's Avatar
Consumer Reports has a similar classification:
Engine, major. Engine rebuild or replacement, cylinder head, head gasket, turbo or supercharger, timing chain.
Engine, minor. Oil leaks, timing belt, accessory belts, engine mounts, engine knock or ping.
Water pump sounds like "engine major". But then again, depends on what he's going for. If he just needs the car to last 3 months, which's the length of the water pump warranty, then fine. If it's a keeper, then factory sounds better.
Dr J
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
