Give Gas, she stalls....help
Old Nov 9, 2008 | 05:38 PM
Bassbreaker's Avatar
It seems now that I have my CAI installed when I give it gas it stalls or wants to stall...it doesn't make sense. I know My Maf sensor is no good and I unplugged it, but why is the car stalling when I give it gas? Like reving it over 4000 rpm's. This is frustrating. I thougth it was the kinks in the hoses but I fixed that and now it still stalls....any help would be greatly appreciated. Thanks in advance
Old Nov 9, 2008 | 05:43 PM
95max327's Avatar
are you sure its not the maf? maybe not enough air and too much fuel? what other performance parts do you have? any fuel upgrades
Old Nov 9, 2008 | 05:45 PM
i'm quite sure it isn't the maf cause I have it unplugged, and the only performance parts I have it the intake. I know there wouldn't be much power when the maf is unplugged, but when i give it gas it shouldn't stall...
Old Nov 9, 2008 | 05:47 PM
also, when it do rev up a bit, there seems to be a backfireing sound of air coming back through the intake like a puffing sound...this is driving me...
Old Nov 9, 2008 | 05:55 PM
I don't know if this will help in any conclusions but yesterday when i tried it with the maf plugged in i gave it gas and i heard a "pop" sound. An injector wouldn't make a pop if it blew would it?
Old Nov 9, 2008 | 07:12 PM
95max327's Avatar
hmm.. sounds like an air/fuel problem.. i had a s/c thunderbird and without my maf it would backfire out of the exhaust when i would rev it high in neutral and let off.. no maf would make the idle ****ty sometimes as well. i dont think an injector would make a popping sound. when did this problem start occuring? before you unpluged the maf, a little while after, long time after? does it misfire? at high R's in gear does it seem to bogg out or skip?
Old Nov 9, 2008 | 07:15 PM
95max327's Avatar
backfiring is making me think it has something to do with too much fuel.. im assuming check engine light is on because the maf.. but have you scanned the car to see what other codes it may have thrown?
Old Nov 9, 2008 | 07:29 PM
Feldman's Avatar
how about picking up a new maf since you already need one and see if that solves the problem
Old Nov 9, 2008 | 08:35 PM
Snypa's Avatar
i advise the same thing^^^
Old Nov 9, 2008 | 09:57 PM
K.Hall's Avatar
I had the same exact problem and once i bought a new MAF sensor that problem went away.
Old Nov 10, 2008 | 03:56 AM
Ok..I have another Maf off of a GXE I own and I can try that, but, it only started happening after the maf went really. I hooked up the CAI, busted the MAF, left it unplugged and it idled smoothly and she'll idle smoothly right now, but when i give it gas it'll sputter a bit and then stall. And when it do rev up for me, it doesn't rev higher than say 4000 or so and then it sounds like air is coming (puffing sound) back through the intake or somewhere in that area...
Old Nov 10, 2008 | 04:04 AM
also, I forgot to mention...there is no CEL, doesn't misfire really..it'll either rev up and make the puffing sound, or stall as soon as I put the gas down. Even if the maf IS bad, it should still be able to run shouldn't it? Maybe the CAI is giving to much AIR?
Old Nov 10, 2008 | 04:26 AM
Madmax66's Avatar
I just F'd my MAF and it acts VERY similarly however, it does not stall. I only get to about 2500 RPM before she sputters like mad. I AM getting 0304 code for KS which I had just replaced a few months ago....hoping a new MAF will cure.
Hopefully, the other MAF helps!
Old Nov 10, 2008 | 04:37 AM
thanks, i'll try it when i get home, but I don't know what to do if that isn't the problem...
Old Nov 10, 2008 | 05:09 AM
njmaxseltd's Avatar
Cliff notes for this thread:
Guy installs an intake, the maf goes bad, car runs poorly, verified the maf is bad, car still runs like crap, asked the org what to do knowing the maf is bad, car still runs like crap.
Seriously.... CHANGE THE MASS AIR FLOW SENSOR!
You were better off with the stock intake anyway, it gives the best throttle response.
Old Nov 10, 2008 | 05:18 AM
i said I would change it when i got home.....i've also read posts about just cleaning it...maybe that would be the case...also, is a stock CAI gives the best throttle response...then why would people install a CAI
Old Nov 10, 2008 | 06:30 AM
gold96's Avatar
Definatly the MAF. But try cleaning it first. I wasted money replacing it with an aftermarket one. I cleaned the original one, put it back in, and it ran perfectly.
Old Nov 10, 2008 | 06:35 AM
will do, thnaks, btw, would I be able to get that maf cleaner at NAPA? I assume it only costs like 6 or 7 bucks?
Do you only just spray the plugs(male and female)?
I assume you do not spray at the resistor?
Old Nov 10, 2008 | 06:57 AM
Snypa's Avatar
most autoparts store.^^
Old Nov 10, 2008 | 07:51 AM
njmaxseltd's Avatar
also, is a stock intake gives the best throttle response...then why would people install a CAI
Looks and sound.
Old Nov 10, 2008 | 09:41 AM
95max327's Avatar
i dont think the stock intake is the best though... there seems to be alot of restrictions. wouldnt a stillen or nismo be the best intake?
but to stay on topic.. try a diffrent maf, either way you need one right? if its not that then see what it does from there, im sure the maf will deffinatly do something.
Old Nov 10, 2008 | 10:11 AM
yeah, you're right. In the least i'm hoping it will stay going when I plug the new maf in...i'll clean both of them too and see if that makes a difference
Old Nov 10, 2008 | 04:02 PM
modenaf1's Avatar
On all cars I have worked on that I have accidentally left the MAF unplugged, they all usually sputter and/or stall when I give it gas. It makes sense, the engine can't detect that more air is going in, thus it can't appropriately control the mixture. The more gas you give it, the more you screw up the mixture thus the more likely you will stall it. I assume modern cars like the Maxima have some sort of an a/f map so it can generally know what to do based on the TPS, but it may not be accurate enough.
Old Nov 10, 2008 | 07:35 PM
ahh..i see...well i'm going to clean and put on the new maf tomorrow morning...i'll let you know how it goes.
Just out of curiosity ( off topic ) does anyone know about how long it would take to drop a 5 speed out of a car...i have th step by step instructioons...but a time frame would be nice so I can do it before sundown
Old Nov 10, 2008 | 07:51 PM
fishforlife2007's Avatar
u might also check for vaccum leaks..
Old Nov 10, 2008 | 08:41 PM
maxkid123's Avatar
its the maf..get a new one.
Old Nov 10, 2008 | 10:21 PM
KRRZ350's Avatar
check to make sure you didn't switch the maf and boost sensor connectors around, there the only connectors that are the same on the whole damn car and u probably removed both during the intake install.
Old Nov 11, 2008 | 11:33 AM
i only unplugged 2 plugs when i installed the intake...the IAT and the MAF, and they are not alike...i'll try and post pics
Old Nov 11, 2008 | 11:35 AM
I have pics, but i have no idea how to put them on here....
Old Nov 11, 2008 | 11:39 AM
Ok....i figured out one way to do it...lol...go to my profile and i've put the pics in an album with the same same as this thread...have a look and let me know what ya think
Old Nov 11, 2008 | 12:04 PM
ok...i just put in the maf from my other parts car and no change...my altinator squeels but the lights are still strong. when the maf is plugged in, i can start it and keep reving it up but as soon as i let go of the peddle it will stall. When the Maf is unplugged, it will stay idling ut when i give it gas it will stall...i'm getting very close to getting rid of the car...the maf that was on it before was pretty new.....ugh check my profile for pics of it to see anything wrong...i can't figure anything out
Old Nov 11, 2008 | 04:49 PM
First of all, you have to have a good working MAF in the system.
Yes it will idle fine with the MAF unplugged, and stall if gas is applied when the MAF is disconnected. This is normal. What would make you think otherwise?????????????????????? You just can't start disconnecting stuff and expect your car to run normal w/ or w/o gas. I'm shocked no one has mentioned this.
Weren't you the guy would recently yanked the MAF wiring from the MAF and screwed it up? If so, then I bet your connections on the harness side of MAF wiring our messed up. Check those and report back. It's either your MAF, or wiring. Plain and simple.
Old Nov 11, 2008 | 05:25 PM
i am not the guy you are refering about...but...when i have the maf plugged in it stalls w/o gas...
Old Nov 11, 2008 | 07:03 PM
i was told the car could be driven witht he maf unplugged but just wouldn't have any power above 2500rpms...i'm not just assuming things. I just find it weird that with it unplugged it will idle fine but stall when gas is applied and when it is plugged in it will stall then idling but stay going if i keep on the gas...i'm not saying i'm a mechanic or anything...far from it actually, but i'd like to just be able to drive my car....if the IAT sensor is broken, will it cause these symptoms? Like if one of the 2 wires is broken off?
Old Nov 11, 2008 | 07:07 PM
Whoever told you that gave you bad information. A broken IAT sensor would not cause your symptoms. A bad MAF on the other hand would.
Also, you had no problems before you installed the CAI, right? If so, then retrace your steps, you're missing something.
Old Nov 12, 2008 | 04:18 AM
maybe you are right, but from what i cn see, there isn't anything different than when it was stock. I'm going to hook it back up stock today and see if there is a difference. If not, then it is definatly a bad MAF. I'm tryin to avoid this cause they are not cheap.
Check my profile and look at my pics of the intake to see if there are any obvious problems...
thanks
Old Nov 12, 2008 | 08:41 AM
I seen something on youtube where a guy was fixing a MAF sensor. There were 3 wires soldered onto 3 seperate lines type things. It showed the soldering cracked on 2 of the 3 lines and therefore there was no power, stumbling and power loss..maybe I should check that out as well?
Anyone ever open up a MAF before?
Old Nov 12, 2008 | 10:41 AM
modenaf1's Avatar
I mentioned it:
The MAF is one of the most crucial sensors as far as the engine's operation and control of the mixture goes.
All the problems above lead me to believe it is a bad MAF sensor. I say save yourself the headache and find a good MAF sensor to try out and see if it fixes your problems.
Old Nov 12, 2008 | 12:26 PM
I mentioned it:
I will but i'm waiting for a few pm's back from people who have them. I can't afford to buy a new one seeing as they are about $400.
I know it is crusial to the performance of an engine, and i'm hoping a new one will do the trick...
Old Nov 12, 2008 | 12:40 PM
fixerupper10's Avatar
dude just buy a new one i know there expensive but it will just be a better investment to get it now that way if the thing actually goes completley out you dont have to search for a new one. plus i dont think this will change anything but take off your filter and see if theres anything huge trapt in it or maybe something got through it and caught in your maf who knows either way your going to need a new maf soon
