trouble starting in the cold/wet
Old Nov 11, 2008 | 06:04 PM
internetautomar's Avatar
mod or sell?
i have to push the gas pedal to get it to start in the cold/wet. I'm not flooring, I just push it down to let the engine rev a bit, then after 30 secs or so I let it go and the idle goes to 1100 or so and the car is fine.
I'm thinking it's either the CTS or low on coolant (just thought of that as I m typing, I will check the level in the morning).
Anybody else have thoughts on it?
Old Nov 11, 2008 | 08:54 PM
95max327's Avatar
im having the same problem. is your check engine light on?? cause mine is
Old Nov 11, 2008 | 09:40 PM
Snypa's Avatar
Get your^^ cel checked. As for the cold start, it happens to me too in cold times.Last 2 weeks florida was in the high 50's and gave me a lil prob. After it heated up back, i was good again.
Old Nov 12, 2008 | 06:31 AM
mod or sell?
No CEL, I wish there was one. If I had a CEL I would have a better starting point than I do now.
Old Nov 12, 2008 | 08:05 AM
Snypa's Avatar
I agree. Well i sort of had a cel, it was the iat sensor, dont know if it has anything to do with that.
Old Nov 12, 2008 | 11:30 AM
njmaxseltd's Avatar
Check the ECTS
Old Nov 12, 2008 | 12:26 PM
95max327's Avatar
i dont have a obd1 scanner, and ive heard that you can use a paper clip?? and you count the blinks and check the book, but i have the obd1 port and i know they make a scanner, but i cant find one at any parts store, napa doesnt even carry them. most shops dont. only nissan does but they want 98$ an hour and it takes 15 seconds to do but they will somehow make it take an hour lol. anyone know where i can buy a obd1?? or any locals i can meet up with??? im located in wallingford CT. Thanks
Old Nov 12, 2008 | 04:28 PM
Holy threadjack!!
1. Your max is OBDII.
2. You don't need a scanner or even a "paperclip" lol. A small screwdriver will suffice and you can check your codes for free....Read your owner's manual. If you don't have one, get one.
Old Nov 12, 2008 | 08:04 PM
mod or sell?
if you have a code, always check it out first. There have been numerous cases where things that appear unrelated actually are.
Old Nov 13, 2008 | 10:09 AM
95max327's Avatar
Holy threadjack!!
how do i have obdII my car is a early 95 model (3/95) and the port is clearly an obd1 port. my brother works at a parts store and they have obdII there and it doesnt fit and there is no other adapters... i do have an original owners manual that came with the car but i have not found any helpful info in there.
Old Nov 13, 2008 | 10:37 AM
mod or sell?
you do have OBDII, it just isn't in the normal location. The connector your brother (typical part store chuckle head) is looking at is the consult connector.
do a search on here and you will find the location.
Old Nov 13, 2008 | 11:39 AM
I have the same problem on my '96 with the CEL, but thats for the Knock Sensor.
Old Nov 13, 2008 | 01:05 PM
fat_kid's Avatar
check the wiring around your coil-packs. I had the same problem in my camry when it was wet out but it needed a new distributor cap which leads me to believe you may have an uncovered wire or a bad connection somewhere.
Old Nov 18, 2008 | 02:16 PM
Originally Posted by njmaxseltd
Check the ECTS
Agreed. Start there first.
Old Nov 18, 2008 | 04:54 PM
TunerMaxima3000's Avatar
My issue was the same.
It was poor grounding of the starter.
Scan through this if you haven't read it yet --> http://forums.maxima.org/4th-generat...verything.html
Someone mentioned KS, extremely unlikely this will have any co-relation to your problem
ECTS is a possiblity, cheap and easy to change around 15-20$ IIRC. As Im sure you know a failed ECTS doesn't throw a code.
Old Nov 18, 2008 | 05:00 PM
True, but that particular starting problem is usually independent of the weather. Just consistent hard starts. Are you suggesting that regrounding the starter helped your cold starts due to the change of weather/early morning starts?
Old Nov 18, 2008 | 05:23 PM
Yes that's precisely what I'm saying. Not saying this is his issue, but it's possible.
Moisture, temperature (both of engine and ambient) etc. affect connections much more than people give credit I think.
For me my starter/engine was poorly grounded. When the temperature was warm and dry, or my engine was good and hot, the car would start fine.
Any moisture in the air or cold conditions would increase resistance enough to cause hard starting.
As soon as I removed the starter, cleaned mounting surfaces and installed a couple grounds, I never had the problem again.
Side Q to the OP: Why are you giving it throttle? Will the car start if you don't?
It's a common practice to hit the throttle on a hard start, mostly from old engine/car knowledge (carburated). However, this complicates diagnosis on the problem, the car should NOT require you to hit the throttle for it to start. If it does, there are other issues.
Old Nov 19, 2008 | 10:29 AM
mod or sell?
first crank (no throttle) no start.
second crank (a little throttle, not enough to shut off the injectors) it will start and rev up.
today I actually got it to start on the second try without throttle, but it bounced around a bit before settling to 1100rpm. I started it again about 30 mins later and it started first try, and idled at the expected 1500 rpm.
it really does not matter much anymore as I am getting rid of the car, I can't afford the gas mileage anymore.
Old Nov 19, 2008 | 10:31 AM
mrlonglegs's Avatar
cold starts
nissan told customers that in cold weather to depress the gas pedal down
1/4 way and start . Only when cold and 1st time starting for the day.
Old Nov 19, 2008 | 12:43 PM
djluski's Avatar
Cold engine starts then stalls
I have an auto maxima and it starts up in cold weather and with in 5 seconds stalls out. I have to press the gas once its started and then heep it at about 1000 rpms for 20-30 seconds b4 i let off and the engine stays running. I know the issue is not the starter or battery becuase i just replaced both of them 2 months ago. I have a cold air intake on the car and i dont think that is the issue. Where does the problem lie?
Old Nov 19, 2008 | 01:12 PM
ECTS.
Old Nov 19, 2008 | 05:08 PM
You've obiously been around the block, but I have to ask: when you did the fuel filter last?
There are many things it could be, start with the ECTS, its cheap and easy, most part stores stock it.
Check all your connections as I stated earlier.
Hit us back when you reach a conclusion or after you're done that.
Hope that helps!
Old Nov 20, 2008 | 12:42 PM
vramlagan's Avatar
hey people new to the forum...i have a 97 gxe and actually have the same problem, well similar, my car will give a hard start when the engine is cold...however if it is cold out the car will take a few more cranks to start up...changed fuel filter, coolant temp sensor, and cleaned the mas air flow ne other suggestions....
Old Nov 20, 2008 | 01:03 PM
ECTS.
It was poor grounding of the starter. ECTS is a possiblity, cheap and easy to change around 15-20$ IIRC. As Im sure you know a failed ECTS doesn't throw a code.
Check the ECTS
So vramlagan do you just jump into a thread and not read posts?
Old Nov 20, 2008 | 01:40 PM
vramlagan's Avatar
lol...sorry what does ect stand for?
Old Nov 20, 2008 | 01:48 PM
Engine Coolant Temperature Sensor
Old Nov 20, 2008 | 01:49 PM
mod or sell?
I have a new one for mine sitting in my center armrest I may put it in before I sell the car, maybe not
Old Nov 20, 2008 | 02:07 PM
vramlagan's Avatar
oh ok...well i already changed that ne other helpful hints....
Old Nov 20, 2008 | 02:09 PM
If you don't install it I'll take it.
Old Nov 20, 2008 | 03:08 PM
Gismo-T's Avatar
B!tch We Got a Problem
Hey , what are you waiting for...put it in!
Had the same exact problem with my '98 I-30T...Changed the ECTS, problem fixed...
Old Nov 20, 2008 | 06:45 PM
mod or sell?
time, weather, inclination.
how much coolant came out when you changed yours?
Old Nov 21, 2008 | 03:53 AM
Gismo-T's Avatar
Do it Sunday, doesn't take much time at all, weather will be sunny in the mid 40's. to work on your car.
As soon as coolant stated coming out I put the new one on, just a few ml. of coolant lost.
Old Nov 21, 2008 | 09:04 AM
mod or sell?
well I got ambitious and did it this morning.
my buddy has a heated garage that i work in so it negated the freezing my fingers off factor.
I had 0 coolant come out when I got mine out. it was a bit of a pain to do since I didn't have a crows foot to use and was doing it with a wrench or 2.
I did it at the same time as doing my PS cooler bypass, and adjusting my belt tensioner and checking my brakes.
Dang car has fairly new brakes but they are Duracrap golds so it feels like crap. at least I know I don't need to swap pads yet. I'll let my parents do that, they are getting the car from me and I'm getting their POS in return.
Sunday morning we will see if the ECTS was my issue or not. I certainly hope it was
Old Nov 21, 2008 | 01:54 PM
loxety's Avatar
I've read in this forum that starting issues can be corrected by running a grounding cable from your negative terminal to a bolt on the starter. seems to be a common problem.
Old Nov 21, 2008 | 02:04 PM
It better be.
Old Nov 21, 2008 | 05:56 PM
If you release the pressure from the coolant system you shouldn't have any coolant leak out.
Old Nov 22, 2008 | 05:06 PM
mod or sell?
It better be.
it wasn't
now to search for cleaning the IAC.
anyone else have thoughts?
I may just grab the scanner and check values before I start it.
anyone have a list of the correct values?
I need to fix this for my mom since she is getting the car from me.
Old Nov 22, 2008 | 05:08 PM
mod or sell?
that would fix a problem with trouble/weak cranking over.
I crank over just fine, it's getting the idle that is an issue.
Old Nov 22, 2008 | 06:46 PM
Thats not accurate.
It's not uncommon for the car to crank just fine, but not start simply due to poor starter/engine/tranny ground.
My car cranked NO problem, lack of ground just didnt allow the CPS and starter to actually get the engine running.
Many people have been confused by this, I was, but just cause it cranks fine, does NOT mean there is not a ground issue.
Old Nov 23, 2008 | 06:45 AM
mod or sell?
Thats not accurate.
hmm....
I'm putting in a new battery tomorrow. I may add an engine ground while I am at it.
did you have a consistent cranking speed?
I am replacing the battery because the one in there is who knows how old and the corrosion on the positive side is major, plus my last I30 had a running issue that turned out to be a pooched battery. Besides a good battery is piece of mind that my parents won't get stuck somewhere (they are getting the car)
